Re: Need Help with WS Trans Fluid & Pink Toyota Coolant
Mixing GREEN with the PINK or RED has the potential of causing the mix to GEL.
I recommend highly against it.
The Red and Pink can be mixed without harm that I know of.
They do contain different ingredients.
When I do my t-belt @90K I will be changing from the RED to the PINK.
25 yrs with TOYOTA
