  #118 (permalink)
Old 07-17-2009, 04:21 PM
GORILLA GORILLA is offline
Last Online: Yesterday 07:15 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
Default Re: Scangauge II Install (so easy a caveman could do it)
hi, mine is mounted on top of the steering column.
the wire is fed through the steering column & down to the obd2 port.
all tucked away.
i used a wire hanger with tape, to feed the wire harness through.
after that ,you need to input your info,such as: 26 gallons tank, V8, 4.7l, etc.
there a long code for the X-gauge for use of horse power, as 1 of the gauges.
yes, it is simple to install, but the inputtting of info might give you a headache.
also as per the company, it is best to start out on a full tank of gas.
gorilla
