Re: Starter / Replacement Contacts
There should be no difference, you have to remove the intake manifold and the S/C stays attached to it, you dont have to remove it. The labor should be the same.
We get 4.5 hrs labor (ALL DATA TIME) + either a starter or the contacts, the decision is up to the customer.
25 yrs with TOYOTA
