Re: New LT Yokahama HTS for the 5er
Well; update on the tandom experience with the new LT's.
Everything went well, and there was not much difference in sway but it seemed to take the higher speeds when passing better.
We set up camp in a spot in the sand where it was tough getting out. The sand was very deep and loose, so we had to lower all the tires to 20 psi to get out. Hooked up to the 5er with one tundra, and hooked the other tundra to it and hammered down. You should have heard the sound of that; it was sweet sounding from what i was told. Imagine 2 tundra's with magnaflow exhaust at full throttle in 4-lo redlined in first, then tap into 2nd when we gained momentum. It was badazz to say the least. You should have heard all the cheers with the audience on the beach. It was sweet.
