Old 09-02-2009, 09:48 AM
SE2000's Avatar
SE2000 SE2000 is offline
Last Online: Today 12:35 PM
SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all. SE2000 is a name known to all.
SE2000's Photo Albums
Default Re: Is an air bag a progressive rate spring?
If you look at a progressive rate spring, it is obvious. Instead of a smooth spiral coil, the coil has some close and some farther apart. you get the low weight spring working when the vehicle is empty and it is a softer ride. As you add weight, the heavier part of the coil comes into play and keeps you from bottoming out. On the tundra leafs, the bottom flat leaf does the same thing
On a shock, the only increased dampening is if the shock is designed to dampen at a higher rate if the piston is lower than normal.
