Re: rear diff lock
Must be in 4-lo (unless you do the mod to allow it in any range) and then it will blink until it is engaged. The more you use it the easier it will go in. After you push the button in 4-lo it helps if you can drive several feet and even better if you can turn a little while driving. This helps the gears line up so they can be locked.
