  #30 (permalink)
Old 10-06-2009, 09:39 AM
bill3508 bill3508 is offline
Last Online: 10-29-2009 10:16 AM
bill3508 will become famous soon enough.
bill3508's Photo Albums
Default Re: Change To Synthetic Motor Oil Or Not
Originally Posted by GORILLA View Post
hi quick info. if you bought a used tundra, and you can get the info as to what oil was used. use that.
if your vehicle used reg. oil for 30,000 miles continue to use reg. oil. if it used syn. oil continue to use that.
never go back & forth.
or change after alot of miles.
i got this info from several different performence shop's.
how good is this info, i'm not to sure. but i only use reg. oil, but i change it every 2000 to 2500miles.
oil gets dirty from the dirt in the air passing through & into the engine.
so the cleaner the oil the less dirt in your oil.
so continue to use what ever they used before.
unless it's brand new. than use what you want, but do not change.
gorilla
You can change to synthetic oil when ever you want, back and forth, mix it, doesn't matter. Synthetic does a much better job of protecting your engine and keeping deposits out. Only thing you have to look out for is if you already have an oil leak changing to syn could cause it to become worse as it cleans out all the dino deposits plugging the leak.
04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40
