  #31 (permalink)
Old 10-06-2009, 02:43 PM
Remmy700P's Avatar
Remmy700P Remmy700P is offline
Last Online: Today 02:02 AM
Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold. Remmy700P is a splendid one to behold.
Remmy700P's Photo Albums
Default Re: Change To Synthetic Motor Oil Or Not
Originally Posted by GORILLA View Post
hi quick info. if you bought a used tundra, and you can get the info as to what oil was used. use that.
if your vehicle used reg. oil for 30,000 miles continue to use reg. oil. if it used syn. oil continue to use that.
never go back & forth.
or change after alot of miles.
i got this info from several different performence shop's.
how good is this info, i'm not to sure. but i only use reg. oil, but i change it every 2000 to 2500miles.
oil gets dirty from the dirt in the air passing through & into the engine.
so the cleaner the oil the less dirt in your oil.
so continue to use what ever they used before.
unless it's brand new. than use what you want, but do not change.
gorilla
Hey Gorilla~
I think I'm gonna have to disagree with your conclusion here. Other than the potential for a light seepage by switching away from dino to syn (if the leak was already there, btw...), then there is nothing wrong with using synthetic, switching back and forth, mixing dino and synthetic (at the same v-rating of course...), etc. As long as the engine has sufficient volume of proper viscosity lubrication, all is fine.
Duff
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Step Bars | Kobalt LP Bed Box | FR: Daystar 2.5" Lift, RR: Wheeler's 1" Block
LT265/75R16 Nitto Terra Grapplers 119Q 8-ply | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
Mobil-1 Syn 5W-30 | Mobil-1 Syn ATF | Magnefine ATF Filter 3/8" | NGK Iridium IX Plugs #BKR6EIX | Russell Speed Bleeders #639560
Josh's Billet Wing Window Latch Upgrade | CBMTA Member! | 3/1/2009: 49,693 miles
* * * I highly recommend Auto-Rx for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY * * *
"I finally found an honest mechanic. He honestly doesn't know how to fix anything."
