Re: Check Engine Light @ 60K
It's best to pull the code to see what it is, unless you knowingly tripped it.
One of the easiest ways to clear the CEL is to disconnect the negative battery cable for about 30 seconds to 1 minute. If you don't want to lose your stereo memory and clock setting, you can pull all of the EFI related fuses. Usually EFI and EFI-2 will do the trick.
2005 Tacoma Double Cab V6 4x4 w/ TRD Off-Road pkg., Auto
1991 MR2 V6 (1MZFE)
