Re: New Leer XQ100 slight issue if you are considering
I just removed my cap because of the same problem with the back corner. Problem is, check the other four corners of your bed. I just pulled the cap off to fix that one corner and ALL FOUR CORNERS of the bed have been rubbed and chipped away. I've had the cap for 3 months and its already messed up the bed. This seems to be a problem other than just my Leer cap fit issues.
Chris 1976....definitely check your entire bed,,,better to find out now than when rust starts setting in. For the prices charged for the fiberglass molds,,,,these things should fit with NO RUBBING,,,,,
