Old 06-28-2003, 10:03 PM
v8Toilet's Avatar
v8Toilet v8Toilet is offline
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Default Re: Sludge
Originally posted by acme
The sludge problem was with a faulty PVC system design on older Toyotas. The crankcase wasn't venting correctly and the vapor didn't have a place to go except lining your heads and valve covers and inside your block , it just turned to a soild , sludge......
Alan
If the positive crankcase ventilation system wasn't working properly the crankcase pressure would build up and cause oil leaks.
There is no way I would risk running such an expensive engine like the I-force V8 for 25,000 miles on the same six quarts of oil. I'll stick with the 7500 mile interval that Toyota recommends regardless of what the oil manufacturers say. I may be ignorant in saying that but then I don't put the synthetic oil in to get extended oil intervals. I do it for the reasons I stated above.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
