Old 03-28-2002, 04:28 PM
nhparrot's Avatar
nhparrot nhparrot is offline
Last Online: Yesterday 08:35 PM
nhparrot's Photo Albums
Default synthetic oils - yes or no?
Topic: synthetic oils - yes or no?
dogzpaws
TS Supporter
Member # 383
Member Rated:
posted 02-27-2002 03:57 PM
quote:
Originally posted by richus:
I'm usually very skeptical about being able to notice changes from dino to syn oil, but I agree with the cold running comment. I recently changed the transmission to Redline synthetic, and I definitely notice smoother shifting when the truck is cold.
I noticed smoother shifting with synthetic in the tranny even when the engine is warm.
dogzpaws
2000 Tundra SR5 Access Cab V8 4x4 Jade
Posts: 29 | From: La Mesa, CA | Registered: Feb 2002 | IP: Logged
richus
TS Supporter
Member # 1485
Rate Member posted 02-27-2002 09:11 AM
Posts: 5 | From: cal | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Platinum TS Supporter
Member # 73
Member Rated:
posted 02-27-2002 08:13 AM
Fred I have had the syn oil in the rearend for about 10,000 miles now. Sometime VERY soon I will switch the tranny over too. I have started to notice that when the truck is cold, you take off then let up on the accelerator the tranny won't shift into 2nd gear very easily. Was thinking that the syn oil might help smooth this out. Once the truck (tranny) is fully warmed up this characteristic tends to go away. Overall I thought the syn tranny fluid would just help smooth the shifting out even more.
SATundra
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
RagerXS
Supporting Vendor
Member # 470
Member Rated:
posted 02-27-2002 07:58 AM
quote:
Originally posted by SATundra:
I haven't noticed the MPG increase but I did notice that the engine has taken a different sound. And by different I mean it seems to be not as loud which also means you can more 'clearly' hear the the engine running. Does this make sense or am I just making this up?
Well, I will say I think mine sounds BETTER, smoother sounding than before. Won't push it any further than that though.
SATundra
You will find that synthetic lubricants in your transmission and differentials will have a greater impact on fuel economy.
~ Fred
www.NewEnglandSynthetics.com
"Certified AMSOIL Dealer"
Tundra Solutions Sponsor
Posts: 73 | From: Wakefield, MA | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-25-2002 04:44 PM
quote:
Originally posted by dogzpaws:
I haven't noticed the MPG increase but I did notice that the engine has taken a different sound. And by different I mean it seems to be not as loud which also means you can more 'clearly' hear the the engine running. Does this make sense or am I just making this up?[/QB][/QUOTE]
SATundra
dogzpaws
TS Supporter
Member # 383
Member Rated:
posted 02-25-2002 01:41 PM
Well I have had the synthetic motor oil in for about a month now and can say that "I" have noticed about a 1-1.5 MPG increase so far. Also I have noticed a definate quieting (not as load) sound to the motor. Just seems to purr now. The oil pressure does differ a little from the dino. What has anyone else noticed when switching from dino to synthetic motor oil. Good or bad.
SATundra
dogzpaws
SATundra
Moderator
Member # 73
Member Rated:
posted 02-24-2002 08:23 PM
quote:
Originally posted by nhparrot:
Joe,
When at the AVlube site ckick on the Automotive link and then scroll down to the bottom of the page - The Super Magnet Plug is there.
Thanks Glenn I just didn't look far enough, thought it would have been under the plug.
SATundra
nhparrot
Moderator
Member # 12
posted 02-24-2002 06:48 PM
Joe,
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-24-2002 05:55 PM
George thanks for your vote of confidence on the Mobil 1 and filter. It means alot to me coming from you. Next is the Super Magnet Plug.
BTW I went to the Avlube.com site Glenn posted below, super plug, but only saw one for a big cat motor, guess we just need to call them for pricing and info.
Let me ask this here, as the old site info is gone. Under NORMAL driving conditions alot of highway miles, is 5-6,000 miles ok between oil and filter changes with the syn. What has YOUR experience been from the reports you have seen? Thanks.
SATundra
nhparrot
Moderator
Member # 12
posted 02-24-2002 05:12 PM
aika
Super Magnet Plug
Toyota Sequoia, Tundra, 4Runner V6 Highlander, V8 Landcruiser Super Magnet drain plug. This is NOT your average magnetic drain plug! This plug uses a space age magnet 10 times stronger than regular magnetic plugs. So strong that it actually serves as a very effective filter, constantly removing ferrous from your engine oil. This in turn greatly reduces associated soft metal (brass/bronze/aluminum) wear and allowed the engine oil filter to more efficiently filter other non-ferrous contaminants. And of course if there is a failure occurring, it will be shown immediately on the Super magnet plug. The plug is beautifully machined from stainless steel which means it will last forever, as will the magnet structure. No more rounded off corners on the drain plug! Transforms oil changes into engine wear evaluation.
Available from avlube.com
When changing the filter, lube the gasket with a lttle fresh oil.
I have not replaced the crush ring on my drain plug in 8 oil changes.
~Glenn~
Moderator
aika
TS Supporter
Member # 87
Member Rated:
posted 02-24-2002 02:32 PM
supermagnet drain plug? what the heck is that? ive never heard of it before. also, with the mobil 1 filter, should i have lubricated it with a little bit of oil to seal the filter better. i figured i didnt have to because it said that it was internally lubricated. no leaks yet so i suppose i did just fine... with the drain plug- do i ever have to replace the little sealing washer?
Posts: 154 | From: San Diego, CA | Registered: Feb 2002 | IP: Logged
georgeseq
TS Supporter
Member # 1424
Member Rated:
posted 02-24-2002 09:57 AM
The Toyota OEM filters are a cut above most other manufacturer's, both air and oil. The Mobil 1's are another level above the Toyota's as are several other premium oil filters. The Mobil 1 uses a synthetic medium which filters effectively down to 10 microns and holds nearly double the contaminants of a paper medium oil filter. Same can be said of other synthetic media oil filters such as AC Gold, etc. Combine a high quality oil filter with a super magnet drain plug and you are 'there'..... I use either the AC or Mobil 1, along with super magnet drain plug on my Sequoia and the oil analysis results are about as low a level of iron I have ever seen in a gasoline engine.
George
Posts: 13 | From: Columbus, ohio | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-24-2002 09:54 AM
SATundra
Possum
Super Moderator
Member # 161
posted 02-24-2002 02:20 AM
I just changed my oil to Mobil 1 5/30 and am using the Mobil 1 filter as well. I got the oil at Walmart and had to purchase the filter at the local auto shop. It seems to be a smoother drive but my gas mileage has dropped some. But then again, I have been a little more heavier on the foot.
Dan
Dan-Texas Forum Moderator
Posts: 624 | From: Houston, TX | Registered: Feb 2002 | IP: Logged
aika
TS Supporter
Member # 87
Member Rated:
posted 02-24-2002 01:33 AM
just got done changing my oil. used mobil 1 filter, and mobil 1 oil. wonder if it really is better. whatever- if theres a chance that its better then ill go with it. i wonder if ill be able to tell a difference just in how smooth my engine runs. i like to think i can tell when its running smooth or not. by the way, do all of you guys pull your brush guard off before changing the oil and oil filter? its a heck of a lot easier to get in there when its off... i found that the places i had taken it to before had lost TWO of the bolts and washers that hold my brushguard in, on top of losing my oil cap (made sure they replaced that with the oem oil cap though)...i guess its off to the dealer to get more bolts...
SATundra
Moderator
Member # 73
Member Rated:
posted 02-21-2002 08:58 AM
quote:
Originally posted by aika:
do you guys think that a mobil1 filter would be better than the stock toyota filter? i have to change my oil in about 20 miles, so what should i use with mobil 1 oil (that synthetic stuff... ). would you think it didnt matter. if i remember correctly, the toyota filter was supposed to be pretty decent...opinions wanted!
Yes the Mobil 1 filter should be even better than the Toyota. I got my Mobil 1 filter for $10 at a local auto parts store. Maybe 1 of these days Wal-Mart will even start carrying the Mobil 1 filters.
SATundra
KDTundra
TS Supporter
Member # 599
Member Rated:
posted 02-21-2002 01:15 AM
I used to use dino oil in my previous vehicles and had no oil related problems with 3000 mile oil/filter changes. I switched to Mobil 1 when we bought our 99 4Runner and 01 Tundra. I use the 7500 mile oil change interval per Toyota rep on both. I too was concerned about the oil filter as I've used Toyota's OEM on both (4Runner has 38,700 and the Tundra 7800). From previous posts, it seems that Mobil 1 oil filters as wellas Amsoil filters were rated superior in cleaning capability and dirt retention as compared to many others. Someone posted a web site where the test results were discussed. Toyota filters weren't specificaly mentioned in the test so you can't draw a conclusion about the OEM filters versus the aftermarket ones listed. I don't see you going wrong with a high end aftermarket filter. Some think it's a waste of money. I still believe you get what you pay for!!!
After all that, I'll probably go with the Mobil 1 oil filter (can't find Amsoil locally) because of the longer oil change intervals and protect the investment we have in the Toyotas. I was a little concerned about using the OEM filter with the longer oil change interval.
Good Luck!
Kev.
Posts: 15 | From: Fulton, Missouri | Registered: Feb 2002 | IP: Logged
aika
TS Supporter
Member # 87
Member Rated:
posted 02-20-2002 11:09 PM
EZ2BME
Member # 97
Member Rated:
posted 02-16-2002 09:22 PM
I started using Mobil1 5w30 & Mobil1 filter at 500 miles. At 6k, continued with Mobil1, but switched to German filter. Some folks will still argue that dino oil works as well, and synthetics are a waste of money. That will always be debated.............
John
01 Limited (Jade/Mica) 2WD TRD, XM Radio, Infinity spkrs, Alpine amp, TRD air filter, BORLA split-side catback, Hella Supertone horns.
Posts: 257 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
lelandstanford
TS Supporter
Member # 539
Member Rated:
posted 02-16-2002 03:46 PM
I just had the 1st oil change. Deutsche (Champion Lab) filter is about 1 cm shorter, too.
Factory Add-Ons: running boards, RS3000+
Aftermarket Add-Ons: Bumper Opening Screen, Tint, Carbon Metallic Brake Pads
Mods: DRL & DEF Disabled, Fog Light 2C, Map Lights, Headrests
Posts: 64 | From: Houston, TX | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-15-2002 02:20 PM
Just thought I would start this thread again as it had been a popular one before the crash of '02.
BTW - I switched to syn oil 3 weeks ago at 16,000 miles. Mobil 1 5W-30 with Mobil 1 filter. Did notice that the Mobil 1 filter was shorter than the Toyota one. Heh.
Joe - SATundra
