Old 07-10-2003, 03:28 PM
DJ DJ is offline
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
Originally posted by jaimr
Thanks DJ for the response, we really appreciate your comments. Once again you have taught us something. You have talked me right out of using adapters. But, the wheel search will continue!!!
Please keep something in mind in your search for wheels.
Suppose you were to use a spacer or adapter to space the factory wheels out from the hub. Compare that to not using a spacer or adapter, instead using a different wheel with a "deeper dish" that moves the tire out the same distance the spacer or adapter did. From the point of view of the effect on the suspension, THERE IS NO DIFFERENCE BETWEEN THE TWO SITUATIONS.
Perhaps I wasn't clear on that point.
I don't like the idea of spacers or adapters because of the potential of weak mounting, runout, and imbalance of the whole assembly. My primary concern is the effect on the suspension of spacing the wheel out from the hub compared to where it was designed to be. The effect of moving the wheel out is the same, regardless of whether it was done with a spacer, and adapter, or a different wheel.
