I haven't heard that anyone has diagnosed a problem. A number of folks are complaining, has ANYONE identified a real problem so you can talk intelligently to Toyota? If you want a real fix - know what needs to be fixed. Someone with the "complaint" should measure the input voltage and the output voltage of the amps. That will tell you if there is a possible amp OR a head unit problem and provide you the data to make an intelligent complaint to your Service Department. Without the facts you are a victim to whatever anyone wants to tell you.
~Glenn
