Originally posted by Eddie
I'm using a 1.5K ohm resistor for the air temp sensor. A 0-2K ohm linear taper pot for the water temp sensor. There's also a SPDT switch wired after the pot to switch between the pot and a 180 ohm resistor. They're 1/2 watt resistors by the way.
Since you're "piggybacking" the sensors I'd use a higher resistance pot,like 5K ohm. I'm trying to create hotter readings,not cooler.
The box and my multimeter are at work,I'll bring both home tomorrow. I won't be able to get you the actual resistance values vs. temp readings until Monday since I'll be out all weekend.
That would be very kewl!!!
Thank you for doing that.. I hope you have a great and SAFE labor day weekend!!!
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
