  #62 (permalink)
Old 08-30-2003, 10:38 PM
tremo's Avatar
tremo tremo is offline
tremo's Photo Albums
Last Online: 10-27-2008 10:52 AM
tremo is on a distinguished road.
Send a message via AIM to tremo
Default Hellwig How-To
Good tips! FYI that I also wrote a How-To guide complete with pictures available to Club Members under: HOW-TO:Install a Hellwig Anti-Sway Bar on a '02 Toyota Tundra
Re:
5. Made sure I mounted the U-Bolts outside of the brake line mounting brackets. I know through all the threads that this is the preferred place. I also see that the Wheelers Off Road website shows the install in the same location. Good enough for them, then good enough for me.
Actually, I don't think this is correct. Here's a pic of my install:
http://www.tundrasolutions.com/photo...cat=500&page=2
If you mount the U-bolts on the OUTSIDE of the brake line mounting brakets you will be off-center as to where the bushings need to mount on the sway bar. e.g. Each bushing needs to mount in the straight section of bar, not the curved section as would be the case if you mounted the U-bolts on the OUTSIDE of the brake line brackets.
The picture on Wheeler's web site is in error. Look at the right U-bolt...it's not even straight! (It's a poor representation of the "proper install" if you ask me.)
You will more properly load the sway bar if you mount the U-bolts perpendicular to the sway bar...
Seee-ya,
Jim.
Base: '02 Tundra SR5 Imperial Jade Mica 4WD w/ TRD Off-Road, EVP Convenience & Tow Packages, Oak Interior & Captains Chairs, 6 Speaker/6-Disk CD, VIP 3K, Chrome Wheel Locks, & Anti-lock Brakes with DRL
Mods: K&N FIPK II, Ram Air Performance System (RAPS), Unichip, Ivan Stewart Flares and TRD Grille, 2" Cornfed Front Suspension Lift (How-To Guide), BFG A/T 265/75's, Hellwig Rear Anti-Sway Bar (How-To Guide), JBA Headers & 2" Highflow Y-Pipe, 2.5" Exhaust Cutout with QuickTime Performance Electric Cutout (QTEC), Flowmaster 50 Series™ Delta Flow® Performance Muffler with Dual 2.5" x 18" Chrome Tips, ASP Racing Underdrive Pulley, PPD Billet Goodies, Rhino Liner, Tinted-windows, etc.
Planned: My Tundra is done for now. Next up: Build new 400ci for my '69 Pontiac Custom S
