Old 09-08-2003, 12:41 PM
makana81's Avatar
makana81 makana81 is offline
Last Online: 07-08-2005 06:38 PM
makana81 is on a distinguished road.
makana81's Photo Albums
You could always attempt it yourself---get four 1/4" (minimum thickness) x 2" (wide) x ? (distance to move seat back plus 1") steel plates. Drill 4 holes slightly larger on one end of the plate and drill & tap another 4 holes 10 mm x 1.25 on other side of bracket.
Note: The addittional 1" clearance is to move the drilled locations 1/2" in from edges minimally---increased clearance ups the rigidity.
Make sure you pick up more bolts (4 each 10mm x 1.25 x 30mm [dependent of thickness of plate purchased]), these will be used to fit thru the slightly larger drilled holes and mount to the original locations with the longer bolts. The 4 bolts removed earlier will be used to mount to the brackets drilled & tapped holes.
Added benefit to the mod is the raising of the seat.
Or, take the seat out of the truck and to a metal/welding shop, they should be able to fabricate mounting relocation brackets that move the seat back a few inches. Just ensure you clearly explain what you want.
Hope this insight helps, Good Luck.
