rear axle seal TSB READ THIS!
Turned the TUN in for an oil change and check my rear drum (that has already been TSB'D), it was leaking fluid out for the rim. Get back to the dealer. Rear axle seal busted, flooded my drums. So theyre gonna keep it overnight and replace the seal and my rear again. anybody notice axle grease or brake fluid leaking from the rear, turn it in. This will be the 2nd job on the drums, one or 2 more times, Ill probably switch to 4 disc if anybody is interested in a group buy (sequioa rear conversion, trd, brembo, stop-tech fronts). Hope this helps.
