Originally Posted by TUNDRAV8GEORGIA
Tundra brakes have been a joke since day one ..It was interesting talking to a sale's guy at my toyota dealership today. He asked me how i liked my truck and i informed him the truck is great. but the brakes being a joke and toyota putting in tacoma pads when it came out in 2000. MY problem has been corrected since the tsb performed back in sept 2002 in which the f/e has revisions done to the brakes in which i noted today the sequioa uses the same brake capliers my tundra has on right now. So far it's been a good match with no problems or vibes to report...
The sales department also informed me today that the tundra d/c due out will arrive at my dealership in 3 to 4 weeks and i'll keep you posted when i do the first test drive since they know me pretty well out there...I do know tundra d/c, will have 4 wheel disk brakes. By the pictures i've seen and hopefully we might expect to see a part number we can buy to maybe update our tundras we have now....
Brake changes for '04
Brake control system (ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 2WD models.
Brake control system (ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 4WD models.
Brake Control System ’04 Toyota Tundra
ABS - Standard
ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD - Option (2WD)
ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD - Option (4WD)
On the Brake Control System (ABS) model, the deceleration sensor has been changed from the type that was built into the skid control ECU & actuator to a separate type.
On double cab model with Brake Control System (ABS), a brake pressure conversion unit has been added between the brake booster and the master cylinder in order to provide the proper braking force when the brake booster has no vacuum.
NO REPORT OF 4 WHEEL DISC BRAKES
