09-19-2003, 01:25 PM
Banned
might be right on that
Originally Posted by nhparrot
Brake changes for '04
Brake control system (ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 2WD models.
Brake control system (ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 4WD models.
Brake Control System ’04 Toyota Tundra
ABS - Standard
ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD - Option (2WD)
ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD - Option (4WD)
On the Brake Control System (ABS) model, the deceleration sensor has been changed from the type that was built into the skid control ECU & actuator to a separate type.
On double cab model with Brake Control System (ABS), a brake pressure conversion unit has been added between the brake booster and the master cylinder in order to provide the proper braking force when the brake booster has no vacuum.
NO REPORT OF 4 WHEEL DISC BRAKES
i was going into toyota site in fact and didnt see any information on rear brakes on the tundra d/c..If you look at all pictures currently for the tundra d/c you see a disk on the rear however i have yet to see a tundra d/c with a calpier on the rear which gives me the impression toyota is using drum brakes with a disk like object in the rear whatever the case is ill guess ill find out in a few week's when i take the first test drive when my dealership get a hold of the new tundra d/c in 2 week's when i get drive one and be one of the first...
