09-20-2003, 01:13 AM
Originally Posted by nhparrot
Brake changes for '04
Brake control system (ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 2WD models.
Brake control system (ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD) is newly adapted as optional equipment on 4WD models.
Brake Control System ’04 Toyota Tundra
ABS - Standard
ABS with EBD, Brake Assist, TRAC, VSC and Auto LSD - Option (2WD)
ABS with EBD, Brake Assist, A-TRAC, VSC and Auto LSD - Option (4WD)
On the Brake Control System (ABS) model, the deceleration sensor has been changed from the type that was built into the skid control ECU & actuator to a separate type.
On double cab model with Brake Control System (ABS), a brake pressure conversion unit has been added between the brake booster and the master cylinder in order to provide the proper braking force when the brake booster has no vacuum.
NO REPORT OF 4 WHEEL DISC BRAKES
What is Auto LSD? Is that some sort of electronic LSD?
