Old 11-20-2003, 01:21 PM
mike.elmes's Avatar
mike.elmes mike.elmes is offline
Last Online: 09-26-2009 12:27 PM
mike.elmes is on a distinguished road.
mike.elmes's Photo Albums
Default Acid Flush heater core
Just dropped off my Tundra at the mechanic. Very POOR heating. They are changing the thermistat, and doing a routine flush and refill of the rad fluid. I have had it there before and actually trust these guys. They only work on Honda and Toyota. There is just so little heat. I pulled the main fuse on the A/C, to eliminate the a/c from cycling while on defrost.Last night I pulled the dash apart and there was different wiring than the picture showed in the garage section here so I put it all back together and pulled the 15 amp fuse under the hood that controls the A/C. The mechanic said the Camry's gum up the heater core's and require an acid flush to really improve the efficiency of the heater core so for 50.00 it will hopefully help. Combined with the new thermistat,engine coolant, I hope to have heat....and a lot of it. It was -17C here last night and the truck warmed up quickly and showed the water temp at it's usual mid point, so thats why the mechanic suggested the acid flush.Anybody had that done before?
mike
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
