Originally posted by tuffloud1
I tried changing the spark plugs but I'm not sure what to do. I unscrewed that one screw and pulled off that black square piece and a long black tube came out. Then what do I do?
tuffloud1,
Loosen the bolt and pull off the coil. Each plug has an individual coil. No spark plug wires, no distributor, no rotor. It's a deep well, but the plug is down there. You really need a spark plug socket that has a rubber gasket that will hold the plug in to get the old plugs out of that hole. I think it was a 16mm. There is plenty of room on the passenger side and you can make it work on the drivers side, it's just a bit tougher.
Jose
