Old 12-09-2003, 07:26 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
295 ft-lb @ 0 rpm is near worthless. It'll get you started great from a stop, but then what do you have when the rpms rise?
A hybrid power plant can be made to put out any amount of power at any rpm you want, but the cost and weight might be a big problem.
What would be the endurance of the electric assist? I need one that will give full power all the way up a long hill at 60+ mph while towing a max weight trailer, 11,800# combined truck and trailer weight...and fully recharges on the downhill before the next uphill.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
