Old 01-07-2004, 03:25 PM
maverick2003 maverick2003 is offline
maverick2003's Photo Albums
Last Online: 01-21-2008 07:38 PM
maverick2003 is on a distinguished road.
Is it safe to use Fix-a-flat stuffs on those tires with the pressure sensor?
Thanks
Jack
Originally Posted by floatplane
The tire pressure sensor is in/attached to the valve stem. Deflate the tire completely then unscrew the outside ring/washer around the valve stem. After this is off you can puss the stem/sensor into the tire so it is not damaged when removing the tire from the rim.
I hope this helps.
