Front Brakes and Bleeding Procedure
+ Reply to Thread
Results 1 to 6 of 6
Thread: Front Brakes and Bleeding Procedure
  1. #1
    Junior Member m5allen's Avatar
    Join Date
    Jun 2008
    Location
    Tampa Bay, FL
    Posts
    151
    Liked
    4 times
    Images
    28
    Rep Power
    789
    Default Front Brakes and Bleeding Procedure
    I need to put a new set of front brake pads on my 05 Tundra. I have spent a lot of time reading some of the threads about brake jobs and bleeding the brake lines. I have done a few brake jobs in the past but have never bled the brake fluid.
    Basically, what I have gathered from this Forum is that in order to compress the caliper piston properly, I need to open the bleed valves so that dirt and crap doesn’t make its way into the piston/calipers. And since I am doing that, I might as well bleed the brake lines (my truck has about 26K miles and I am sure this has never been done before).
    After reading all these past threads on the Forum, I have seen a lot of commentary on bleeding brake lines, what brake fluid to use, etc….but I have never really seen a step by step procedure. I just want to keep things simple as possible so I will be using the basic pump the brakes and bleed procedure.
    But I am not really sure how to do this. Do I need to have someone pump the brakes a couple of times until the pedal almost falls to the floor and then open the bleed valve? And how many times do I have to do this per wheel? And I have to keep refilling the brake fluid resivoir, right? Any help is appreciated. Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    "Rosco" Thread Derailer Flashgordon's Avatar
    Join Date
    Apr 2006
    Location
    Da Yooper Eh?
    Age
    54
    Posts
    5,778
    Liked
    92 times
    Rep Power
    220718
    Default Re: Front Brakes and Bleeding Procedure
    Quote Originally Posted by m5allen View Post
    With 26K on the truck, I wouldn't be too concerned about contaminants in your brake fluid.
    If the brake fluid is clean/clear in the master, I'd do the following if all you are doing is a brake job;
    With a "C" clamp, compress the brake piston to fully seated on one side with the caliper removed, brake bleeder "closed". This will push the brake fluid back into your master cylinder.
    *Note*. Make sure the other caliper/s are attached to the truck, touching the rotors so you don't force a caliper piston out by compressing the removed caliper. Make sense?
    OK, do each brake, one at a time, replacing the brake pads as you go. Re-attaching each caliper as you go before compressing the nex caliper.
    This will continually push brake fluid into the master so if your master is full to begin with, it will overflow so you'll want to remove the cap and have a container of some sort under the master to collect the excess fluid.
    *Note...again* Do not open any bleeders as you compress the caliper pistons!
    When you have finished replacing the brakes/pads, press the brake pedal until it's firm.
    Check the level of the brake fluid and add any "New" fluid if needed.
    If you find it necessary to bleed the brakes, do the following after the brake job;
    With a friend, spouse, lover whatever....have them pump the brakes and hold pressure on the brake pedal.
    Starting at the right rear, open bleeder till the person above says "floor". You know they have stroked out the travel of the master cylinder.
    Close the bleeder and have them pump the pedal a few times. Tell them to "hold" and open the bleeder till....you get the idea.
    Next go to the left rear, do the same as above. Then the right front and left front till you are done.
    *Note....yes, again." Check the level of the master ocassionally as you bled the brakes! DON'T LET THE MASTER CYLINDER RUN OUT OF BRAKE FLUID!
    I really don't think at that low of miles and new of a vehicle I'd worry about bleeding the system.
    Good luck and hope this helped!
    Drink more. It probably won't help you understand better, but it just might, and that's a chance worth taking....
    Author;
    Dr. Bundy-AKA-"The Good Doctor"
    "you can take the man out of the ho, you can not take the ho out of the man..."
    Author;
    Our Cigar Smoking Scotch Drinking Lesbian Friend-"Dikkie"
  4. #3
    Join Date
    Jun 2008
    Location
    Tampa Bay, FL
    Posts
    151
    Liked
    4 times
    Images
    28
    Rep Power
    789
    Thread Starter
    Thanks Flash!
    Is it necessary to remove the caliper in order to compress the piston? On other cars, I have always used the hold brake pad, turned it around and pressed in the piston with a big wrench or a C clamp.
  5. #4
    Join Date
    Apr 2006
    Location
    Da Yooper Eh?
    Age
    54
    Posts
    5,778
    Liked
    92 times
    Rep Power
    220718
    Thanks Flash!
    Sure, you can compress the piston that way.
    Author;
    Author;
  6. #5
    Admin from Hell Salty_Dog's Avatar
    Join Date
    Apr 2004
    Location
    Fredericksburg VA
    Age
    57
    Posts
    13,116
    Liked
    483 times
    Images
    597
    Rep Power
    58078
    Thanks Flash!
    You should not have to remove the caliper.
    On each pad, there is a pair of tabs that stick out through which the pins that secure the pad go. Rather than using a C-clamp (which I think is kind of awkward) use a pair of Channel Lock pliers and squeeze the piston back by grabbing the caliper body and a tab on the old pad.
    Squeeze it back, replace the pad, then do the squeeze thing on the opposite pad.
    It should be a five-minute job per side, not counting jacking the truck up and removing the wheels.
    Salty Dog
    You've been... TUNDRASTRUCK!
    Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, JBA Titanium Ceramic Headers, Borla Exhaust, K&N Air Filter, Optima Yellow-top Battery, "Powered by Decals" decal, Flux Capacitor, Brakes: Upgrade to 2004 Calipers, EBC Slotted/Dimpled rotors, Hawk HPS pads, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Kenwood KCA-BT200 Bluetooth Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: BedRug, Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One very large Collie and a High-Energy Shetland Sheepdog who isn't that big, but makes up for it in Tenacity.
  7. #6
    Join Date
    Aug 2014
    Location
    Aurora, Colorado
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    So, the bleeding procedure is done with the engine on or off ?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
