emergency brake light switch
+ Reply to Thread
Results 1 to 4 of 4
Thread: emergency brake light switch
  1. #1
    Join Date
    Dec 2002
    Location
    Huntsville, TX
    Posts
    52
    Liked
    0 times
    Rep Power
    13
    Default emergency brake light switch
    Now, let me begin by saying that this is a Camry problem, but I'm hoping someone out there can help me. The emergency brake light on my son's '93 Camry now stays on all the time. I replaced the switch, but it still stays on. The dealer said that it could be caused by low brake fluid--the fluid is where it is supposed to be. Then they said that it could be worn pads. Neither the pads nor the rear shoes are worn very much at all. Any ideas where to look next? (The dealer couldn't even tell me precisely how the switch works. There is a single lead going to it). Thanks. PR
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lifetime Member HotRod8's Avatar
    Join Date
    Oct 2002
    Location
    Airdrie, Alberta
    Age
    48
    Posts
    241
    Liked
    0 times
    Rep Power
    13
    I am assuming that it's the "Brake System Warning Light", that is on. On most, if not all, Toyota vehicles this light will come on if the Parking Brake is applied or if the Brake fluid level in the master cylinder is low. There is a float switch built into the cap on the brake fluid reservoir that will turn the light on if the fluid level drops. These switches are generally very sensitive, in other words the light may come on even if the fluid level is within the normal range, but not actually full.
    You say that the light is on all the time, did this come on suddenly or did it initially come on only when the brakes were applied? As the pads and shoes wear the fluid level naturally drops slightly, this can be enough to trip the float switch and turn on the light.
    Hope this helps,
    Rod
  4. #3
    Junior Member dupont24's Avatar
    Join Date
    Jul 2003
    Location
    Southeasten, PA
    Age
    38
    Posts
    326
    Liked
    0 times
    Rep Power
    13
    The float in the resvoir is prbably stuck, happens quite often, suck the brake fluid out and clean the float with some brake clean, then refill, you'll be good as new. Don't over do it with the brake clean though or you could damage some seals.
  5. #4
    Join Date
    Dec 2002
    Location
    Huntsville, TX
    Posts
    52
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Quote Originally Posted by rsvees
    Thanks for the tip. I'll give it a shot. PR
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
