Front Brake Pads Rubbing?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Front Brake Pads Rubbing?
  1. #1
    Supporter DaveS's Avatar
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Unhappy Front Brake Pads Rubbing?
    For the past several days, I have noticed a noise the appears to be coming from the front driver's side wheel. It sounds like the brake pads are rubbing against the rotors even when the brakes aren't applied. I checked the master cylinder and the fluid level is just below the MAX line. Nothing has been done to the brake system since I flushed it last summer...
    Today I took off the wheel to look at the pads. It looks like I have about 4 - 5mm of pad left, but I did notice that I couldn't really turn the rotor without encountering significant resistance -- the pads were basically touching it. How much clearance should the pads have against the rotor when the brakes aren't applied? This is probably a really stupid question -- I know nothing about brakes -- but in a somewhat pressurized system like the brake system, what keeps the pads away from the rotors in the first place?
    Any suggestions about how I can fix this condition? Does this indicate too much pressure in the system? Not enough pressure? Something else entirely?
    Thanks,
    Dave
    2001 Silver Sky Metallic 4x2 SR5 V8 Access Cab TRD | JBA Titanium Ceramic Coated Headers | Ivan Stewart Aero Kit | Ivan Stewart Graphics and Plaque | ABS | Auto Dimming Temp/Compass Mirror | Toyota Chrome Tube Steps | Toyota UTR Bed Liner | Hidden Hitch receiver w/ DrawTite Wiring | Toyota VIP 3000 Security System | TRD Floor Mats | Alpine CDA-9811 HU | Sirius Sportster Satellite Radio | Polk Audio DB6500 Components (Front) | Polk Audio DB675 Coaxials (Rear) | Alpine MRP-F450 Amp. | JL Audio Stealthbox | JL Audio 250/1 Amp. | Total Chaos Steering Rack Bushings | Hellwig Rear Anti-Sway Bar w/ Greaseable Bushing Mod | Daystar Front Urethane Bushing Kit w/ Greaseable Bushing Mod | Optima 34R Battery | Russell Stainless Steel Brake Lines | Brembo rotors | OSRAM SilverStar Headlights | Sylvania SilverStar Fog Lights | 5 Michelin LTX M/S Tires and Extra Alloy Wheel for 5 Wheel Rotation | Wheel and Spare Tire Locks | Synthetic Fluids
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Rlockyer's Avatar
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    1 times
    Rep Power
    14
    It is normal for them to touch. The slight amount of runout present in a normal rotor is enough to open the clearance. There are no return springs as there are on drum brakes.
    They should not be TIGHT, but you will encounter fair resistance when turning the rotor with the tire removed. With the tire installed, the mass and diameter of the tire should make it pretty effortless.
    You could have a sticky piston. Go ahead and try to press the pads back to their starting position, then pump the brakes a few times, take a trip around the block, and see if it changes.
    Consider new seals or perhaps a caliper rebuild (or repalcement with the new TSB caliper) on the next brake job.
    2008 Tacoma 2.7 RC Base
    2003 SR5 TRD V8 <<< Sold 2005
    Better Built toolbox / Limited leather / Power outlet mod / RS3200 Plus / Rebadged w/TRD / Bully Nerf bars / '05 OEM Taillights / Clear corners / Factory Woodgrain kit / Gentex EC Mirror / Gaylord's Toolbox-Lid / MB Overdrives / Muthco Signal Mirrors / Sport Grille / TRD Dual Exhaust / Camry Nav System
  4. #3
    Supporter sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,232
    Liked
    3 times
    Images
    8
    Rep Power
    14
    Could be calipers or which I've seen on a lot vehicles, bad hoses. The high pressure rubber ones separate on the inside and collapse. It allows fluid through under presure when you step on the brakes but does not let it back past and holds the pads tight.
  5. #4
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    Quote Originally Posted by Rlockyer
    Thanks for the reply. I already have the new calipers, so I'm hoping that your suggestion about checking for a sticky piston works...
    Dave
  6. #5
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    Quote Originally Posted by sequoiasoon
    That would blow...how is that condition detected without tearing all of the brake lines out?
  7. #6
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    Quote Originally Posted by DaveS
    Dave
    So far, so good... I used a pair of channel locks to work the pads away from the rotor and then pumped the pedal a few times to reseat them. I repeated this a couple of times and then went for a test drive. No noise!
    Dave
  8. #7
    Supporter Picasso's Avatar
    Join Date
    May 2004
    Location
    Dallas, TX
    Posts
    643
    Liked
    9 times
    Rep Power
    249
    Default Dragging Brakes
    Dave
    If your problem reappears, you may want to do a residual brake line pressure test which would tell you if your hoses were deteriorating as sequoiasoon described. All you need to do is to drive around for a few miles while giving your brake pedal light to moderate pressure when you stop. Park your truck, turn off the engine, and open the caliper bleeder of the wheel in question. If it squirts out fluid, you have the problem described by sequoiasoon. It is normal for only a few drops to come out.
    I did this test a few days after flushing my brake lines and discovered black particles in the new fluid. I had no residual pressure though. I suspect that my front brake hoses are coming apart and I'm going to replace them with stainless steel braided hoses. I posted a question about this in this (Completed Front Brake TSB) thread but have not gotten any responses.
    The o-ring seal between the piston and its cylinder is the only thing that retracts the piston after applying the brakes. If there is a problem with this seal, it could cause the symptom that you had.
    Are you going to install TSB calipers on your truck?
    Hope this helps. Good luck.
    Completed Mods:
    S&S long tube headers
    Brembo rotors
    TSB caliper upgrade
    Hawk LTS brake pads
    Stainless steel braided brake lines
    Total Chaos steering rack bushings
    Alignment to DJ's specs
    Century cap
    Line-X
    XM satellite radio module (connected to Pioneer head unit)
    Instrument cluster LED upgrade
    Future Mods:
    Rearview camera system
    BA Muffler (on order)
    Sound deadener
    Fusion Drive
    Flux Capacitor Control Unit (FCCU)
  9. #8
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    I'm still dealing with the rubbing noise... I took it to the dealer and they said that I was close to the end of my pad life, so I bought and installed new pads last week. No change in the noise. I haven't been able to get the rotors turned yet, but I hope to do that next weekend.
    Today, I flushed the brake system and I noticed that the fluid coming from the front bleeders was darker in color and had a few dark particles in it. I flush the brake system every year and I've never noticed this before. I'm wondering if my rubbing noise is due to the deterioration of the rubber brake hoses that sequoiasoon experienced. Should I replace the hoses with stock or just go with stainless. If stainless, has anyone gone with the stainless kit from Stop-Tech?
    Dave
  10. #9
    Join Date
    Mar 2002
    Location
    Buffalo,ny
    Posts
    29
    Liked
    0 times
    Rep Power
    14
    Default Re: Front Brake Pads Rubbing?
    Hey Daves I also have a noise from the front left side. But it only happens when I make a slight left turn. ( like an exit ramp ). I just replaced the caliper on the right side because when I replaced the pads, one of the pistons in the caliper was stuck. Maybe with a little luck having the right caliper replaced ---maybe the noise on the left will go away.
  11. #10
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    Quote Originally Posted by JustDave
    With the hot weather, my noise is back...and I was wrong about it being on the left side. It's actually coming from the front right driver's side. And it only happens in the summer. I've done everything I can think of to the actual brake system short of replacing the caliper. Turned the rotors, replaced the pads, switched to stainless steel brake lines, and flushed the system a couple of times. When I took it to the dealer, they could find nothing wrong. They said that the calipers were in great shape and that there was no evidence of a piston that was sticking. I too have exercised the pistons and they all seem to move freely. The more it continues, the more I think it's a wheel bearing problem...
  12. #11
    Join Date
    Jul 2006
    Location
    Mashpee
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Regarding stuck pads, on 2000 Corolla the left front (that's the Driver's Side, correct!!) inside pad wore badly (other front pads 90% new). Found the cause to be the "wear indicator clip" that fits on top of the inside pad. When bought new pads (CarQuest's Blue Ceramic) seems that metal clip on the end of metal pad backplate also causes too tight a fit in the caliper seat. The metal clips do no come on replacement pads; reuse same as on vehicle. [Note: only way to get new pads to fit into caliper seat without binding is to file down the end (shorten length about 1mm) of the pad's metal plate.]
    So I left out those clips on both left and right sides. I have seen several wear indicators on different manufacturer pads but could figure how these clips work. They protrude away from the rotor and do not appear to touch anything as pads wear. This is how I found them installed, and also as shown in Haynes Manual photos.
    So what harm or danger have I caused by omitting these two wear clips from front brake pads?
    Thanks, DiyEdd
  13. #12
    Join Date
    Aug 2004
    Location
    College Station, TX
    Posts
    267
    Liked
    0 times
    Rep Power
    11
    How much have yall paid for a set of stainless brake lines? I found some online for 158, but that sounds like way too much.
  14. #13
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    489
    Liked
    1 times
    Rep Power
    21
    Thread Starter
    Quote Originally Posted by gquenstedt View Post
    I got mine here for $69 plus shipping and the kit includes the two front lines and the rear center line.
    Dave
  15. #14
    Join Date
    Oct 2006
    Location
    Boston
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by Rlockyer View Post
    I have a Toyota Tacoma 2001 V6 TRD. I have the same problem as DaveS my left front side break was making a noise even when my break weren't applied and thinking that my problem was the caliper because my rotor and pads are fairly new I changed it but now my break is making the noise when I apply it.
    My question is could the rubbing pad damage my rotor and I need to turn it or do I need new pads even dough the one I have is pretty good shape.
  16. #15
    Supporter MEvang's Avatar
    Join Date
    Jul 2005
    Location
    Colerain
    Age
    55
    Posts
    1,217
    Liked
    14 times
    Rep Power
    603
    This is and old post so I read back through it.
    In your case first check the pads, more then likely they are worn out. They could be down to the warning tab or worse down to the metal backing in this case the rotor is likely damaged.
    In Dave's case in which we never known if he got it fixed or it went away, his noise may have been something other then the brakes. A bent backing plate, a wheel bearing noise, or something in the drive axle if his truck is 4 wheel drive.
    Mike.
    “The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
    Moderator Brake Forum
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 02-25-2013, 11:39 AM
  1. EBC 6000 Brake Pads
    By Stooge in forum 1Gen-Brakes
    Last Post: 04-26-2007, 03:45 AM
  2. Brake Pads????
    By Toy4ever in forum 1Gen-Brakes
    Last Post: 11-14-2006, 03:50 AM
  3. Best Aftermarket Brake Pads
    By basmith in forum 1Gen-Brakes
    Last Post: 09-03-2006, 10:42 AM
  4. Sequoia- Front Brake DIY Very Easy !
    By gnb in forum 1Gen-Brakes
    Last Post: 07-12-2004, 05:56 PM
  5. My experience getting post TSB brake pads
    By mitchr in forum 1Gen-Brakes
    Last Post: 07-12-2004, 01:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
