Brake caliper pad pins.....STUCK!
+ Reply to Thread
Results 1 to 8 of 8
Thread: Brake caliper pad pins.....STUCK!
  1. #1
    Join Date
    Dec 2005
    Location
    Fitchburg, MA
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Brake caliper pad pins.....STUCK!
    Tried to do the new rotor pad install this morning....the pins that hold the pads in the callipers are so stuck.......I lubed, banged, pushed , and shoved........they are solid......(love the directions on this site, "just slide them right out") ........Do I drill them out and buy new ones?? Someone must have had this problem........Rats! Sped
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Picasso's Avatar
    Join Date
    May 2004
    Location
    Dallas, TX
    Posts
    643
    Liked
    9 times
    Rep Power
    250
    Default Stuck Retaining Pins
    Quote Originally Posted by Sped
    You're not the only one. Check out this very recent thread. Warning Brake Front Replacement
    If the pins can't be pushed out, then it seems that your only recourse is to do what what is described in the linked thread.
    Completed Mods:
    S&S long tube headers
    Brembo rotors
    TSB caliper upgrade
    Hawk LTS brake pads
    Stainless steel braided brake lines
    Total Chaos steering rack bushings
    Alignment to DJ's specs
    Century cap
    Line-X
    XM satellite radio module (connected to Pioneer head unit)
    Instrument cluster LED upgrade
    Future Mods:
    Rearview camera system
    BA Muffler (on order)
    Sound deadener
    Fusion Drive
    Flux Capacitor Control Unit (FCCU)
  4. #3
    Lurking Member dannozrx's Avatar
    Join Date
    Apr 2002
    Location
    Twin Cities, Minnesota
    Age
    47
    Posts
    39
    Liked
    0 times
    Rep Power
    14
    I posted that warning and that is what I ended up doing with one of 4 pins. I cut it flush with the caliper, hit it with a center punch and drilled it as straight as I could. I started with a really small bit and worked my way up. The pin hole in the caliper isn't perfect any more, on the outside. The inner diameter is fine. Was finally able to punch out the remainder of the pin. Put in new pins with anit-seize and will re-apply every time I rotate my tires.
    2002 Toyota AC TRD 4x4
    1999 Kawasaki ZRX1100
    1998 Polaris XC 600
    1992 Yamaha YZ 250
    1981 JohnDeere 317
  5. #4
    Join Date
    Sep 2005
    Location
    Earth
    Posts
    28
    Liked
    0 times
    Rep Power
    10
    Before you go cutting, have you tried a penetrant such as PB Blaster or Rust Eater? Spray from all angles and let sit overnight and try. Maybe spray them 2 or 3 times. I would try that first.
    05 Tacoma Pre-Runner, Dbl Cab, Long Bed, Sport Pkg
  6. #5
    Join Date
    Dec 2005
    Location
    Fitchburg, MA
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default PB Blaster
    I've got the PB Blaster and I'm soaking them down with high hopes of a succesful and easy removal of the pins this weekend....thanks all for the input.....Sped
  7. #6
    Veteran Member mattjensen's Avatar
    Join Date
    Oct 2003
    Location
    Santa Maria california
    Age
    30
    Posts
    803
    Liked
    0 times
    Images
    8
    Rep Power
    12
    yea thats why when u replace the pads u need to make sure to lube the hell out of those pins, lots of shops just slap the pads in and dont lub up anything, ive ran into quite a fiew problems b.c of no lubing
    mods:
    donahoes,camburg uppers,MT classic II's,BFG AT KO's 285 75 16, spintech sportsman street dumped,braided steel brake lines,powerslot rotors,energy suspension sterring rack bushings, 10 pack deavers, 2.5x8 sway aways with resi (rear).
  8. #7
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    37
    Posts
    6,598
    Liked
    411 times
    Images
    119
    Rep Power
    27120
    Quote Originally Posted by mattjensen
    ...ive ran into quite a fiew problems b.c of no lubing
    Sounds like a personal problem... LOL!!!! I couldn't resist.
    Happy and safe holidays everyone! Back to the thread.
  9. #8
    Lurking Member JoBel_2004's Avatar
    Join Date
    Jan 2005
    Location
    Canada
    Age
    55
    Posts
    22
    Liked
    0 times
    Rep Power
    11
    Default Re: Brake caliper pad pins.....STUCK!
    I had this problem too this summer..They only thing to do is pull out with an hammer and after go to your dealer buy pins.
    After replacement, the best thing to do is to do a check up every year of your pad and galiper by removing the pins to clear service.....
    ________________________________
    tundra TRD 2001
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Replies: 39
    Last Post: 08-30-2007, 10:34 AM
  2. front brake pad v. rear brake pad wear rate
    By barbum in forum 1Gen-Sequoia
    Last Post: 02-24-2006, 08:04 PM
  3. Brake Pad Shift
    By rwkyle in forum 1Gen-Brakes
    Last Post: 11-18-2005, 05:45 PM
  4. How thick is the pad material on new OEM brake pads?
    By RockyMtnRay in forum 1Gen-Brakes
    Last Post: 05-10-2005, 01:30 AM
  5. parking brake light stuck on
    By chrislloyd in forum 1Gen-Brakes
    Last Post: 01-13-2005, 11:23 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
