clicking noise going from park to drive, drive to reverse
+ Reply to Thread
Results 1 to 6 of 6
Thread: clicking noise going from park to drive, drive to reverse
  1. #1
    Veteran Member mattjensen's Avatar
    Join Date
    Oct 2003
    Location
    Santa Maria california
    Age
    30
    Posts
    803
    Liked
    0 times
    Thanks
    0
    Images
    8
    Rep Power
    12
    Default clicking noise going from park to drive, drive to reverse
    whenever i go from park to drive or drive to reverse and give it gas from a stop i get a clicking sound, doesnt sound like driveline play, maybe it is tho. its starting to get worse never really let it bother me till now. sounds like somehtign is braking metel on metel clanking usually does it about 3 times. anybody have any suguestions ??
    mods:
    donahoes,camburg uppers,MT classic II's,BFG AT KO's 285 75 16, spintech sportsman street dumped,braided steel brake lines,powerslot rotors,energy suspension sterring rack bushings, 10 pack deavers, 2.5x8 sway aways with resi (rear).
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Portugue's Avatar
    Join Date
    Sep 2002
    Location
    Hopkinton, MA
    Age
    36
    Posts
    1,022
    Liked
    1 times
    Thanks
    0
    Images
    9
    Rep Power
    214
    Default Re: clicking noise going from park to drive, drive to reverse
    Im not a pro by any means, but I would check your u-joints. I had a similiar clunk when I went from park to reverse. It was a loud click and didn't sound good at all, it ended up that my rear most u-joint was worn and caused that noise. Now its all set. Do you get vibrations on the highway? Its a differnet feeling than tires being unbalanced. Thats another way of knowing it ould be a bad u-joint. Good luck and I hope I helped.
    Joey
    2002 Toyota Tundra TRD Off-Road Package
    Mods: TRD Dual Exhaust, Clear Corners, Aluminum Skid Plate, 2005 Taillights, 2005 Center Console Mod, 10" Subwoofer in Rear Seat Console, blitzsafe iPod interface, Map Light mod, 1" Daystar Lift, Force Stainless Side Steps, Pirelli Scorpion ATR's on 17's, Fog Light Mod Parts 1 & 2C...hopefully more to come
  4. #3
    Join Date
    Oct 2003
    Location
    Age
    30
    Posts
    803
    Liked
    0 times
    Thanks
    0
    Images
    8
    Rep Power
    12
    Thread Starter
    ya know iam really not getting any vibrations at all on the freeway or at any other speed. ill have to get under the truck and take a look after work and look at the u joints. thanks for the imput.
    matt
    mods:
  5. #4
    Join Date
    Sep 2002
    Location
    Hopkinton, MA
    Age
    36
    Posts
    1,022
    Liked
    1 times
    Thanks
    0
    Images
    9
    Rep Power
    214
    Quote Originally Posted by mattjensen
    matt
    no prob matt. Report back when you've figured out what it is.
  6. #5
    Join Date
    Oct 2003
    Location
    Age
    30
    Posts
    803
    Liked
    0 times
    Thanks
    0
    Images
    8
    Rep Power
    12
    Thread Starter
    u joints are fine hummm, looked under the truck pretty well everythign looks good. except my rack boot has pulled it self off teh rack and its spittin all over the place gerrr but thats unrelated.
    mods:
  7. #6
    Join Date
    Jul 2006
    Location
    Lansing, MI
    Posts
    2
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    hello my fellow toyoters
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Driveline vibration.
    By nhparrot in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 03-05-2014, 03:30 AM
  2. engine noise
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 02-27-2011, 08:11 AM
  3. Clicking Noise While Backing Up
    By david37 in forum 1Gen-Sequoia
    Last Post: 08-05-2004, 09:14 PM
  4. a clunk noise when stop or shift to reverse
    By MyToySequoia in forum 1Gen-Sequoia
    Last Post: 05-23-2003, 06:58 AM
  5. Front drive line noise and vibration
    By Marlin Wonders in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 12-22-2002, 03:05 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
