Auto off headlights
+ Reply to Thread
Results 1 to 7 of 7
Thread: Auto off headlights
  1. #1
    Rookie tclass is on a distinguished road.
    Join Date
    Nov 2002
    Location
    Subs of Chi.
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    Unhappy Auto off headlights
    I cannot get my headlights to go off my 2003 SR5 when I lock the doors with the keyless remote? I do not have the auto on-off sensor, which I believe is only on Limited, but the manual states the lights should go off immediately when locking vehicle, or 30 seconds after the last door is closed. Does any have thoughts on why this is the case. Help please?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member shek3 is on a distinguished road.
    Join Date
    Aug 2002
    Location
    Long Island, NY
    Posts
    82
    Liked
    0 times
    Rep Power
    11
    mine go out eventually but if I lock the doors twice they go out immediately....Mike
  4. #3
    Lurking Member fxdxt is on a distinguished road.
    Join Date
    May 2002
    Location
    Greer, SC
    Posts
    24
    Liked
    0 times
    Rep Power
    11
    Once i turn the ignition off and then open the door, my headlights go off automatically.
  5. #4
    Supporter Franz is on a distinguished road. Franz's Avatar
    Join Date
    Feb 2002
    Location
    Carey Ranch, CA
    Posts
    142
    Liked
    0 times
    Rep Power
    12
    My current SEQ & the 2001 SEQ I traded in works the same way.
  6. #5
    Rookie RickP is on a distinguished road.
    Join Date
    Nov 2002
    Location
    San Jose,
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Default Auto off headlights
    I can't find them on my 03 SR5; Is it just on the Limited edition?
  7. #6
    Rookie Gizmo2132002 is on a distinguished road. Gizmo2132002's Avatar
    Join Date
    Dec 2002
    Location
    Houston, TX
    Age
    29
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    No its in all trucks but you need to turn off the vehicle before you open the doors
  8. #7
    Junior Member mechengr is on a distinguished road.
    Join Date
    Feb 2002
    Location
    New York (Mid -state)
    Posts
    67
    Liked
    0 times
    Rep Power
    12
    my 2001 SR5 had the same issue, but once I close the last door, they go out after 30 or so sec's. (if I lock the truck, it still takes 30 sec.). the second push of the lock button on the FOB makes them go out immeadiately.
    Try this.
    keep keys in ignition (truck not running)... does inside light go on when you open door? do you hear "key in ignition" warning chime?
    Reason I say that is that my toggle switch on the driver's side door was bent, causing the pin not to fire. Dianne in Calif. figured this out (local dealer couldn't).
    then see if the rest of the doors cause inside light to go on, may be a bad door trip pin, so that the truck doesn't know you or anyone else got out of it.
    NL
Posting Permissions
  • You may not post replies
  • You may not edit your posts
