Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
Old 06-24-2007, 12:22 AM
98xlt's Avatar
Dealer : Fletcher Jones Toyota
2004 Toyota Sequoia
Last Online: 03-30-2009 10:57 PM
98xlt is on a distinguished road.
98xlt's Photo Albums
Default weak air conditioning
We've never been thrilled with the performance of our AC, especially here in Vegas in the summer. So, when I took the Seq in for the ball joint recall, I had them look at the AC. They called back later and said the thing needed a refrigerant purge and refill. (Cost to me $185.)
I picked up the Seq at the appointed time and yes, it was over 105 degrees that day and the vehicle had been sitting in the sun for a couple hours. However, in driving the Seq home, a distance of over 10 miles on the freeway, the interior of the vehicle never got below about 85 degrees with the cooling control set in the full "COLD" position. I'd say the performance of the AC was worse than before I brought it in. Using a laser thermometer to check, the air coming out of the vents was never below about 60 degrees.
Any other folks had trouble with their AC and what was the cause and remedy?
Old 06-24-2007, 01:40 PM
Chinee's Avatar
Dealer : Ed Morse Delray Toyota Scion
2002 Toyota Sequoia
Last Online: 11-05-2009 11:44 PM
Chinee is on a distinguished road.
Chinee's Photo Albums
Default Re: weak air conditioning
I agree... the AC has always felt weak in the SEQ. Maybe it's the large cabin or the wrap around glass that lets in so much radiant heat, but the air from the ducts should blow colder.
It's been more than 4 years with the SEQ but it's my wife's daily driver, and she parks in a covered garage at work, so the cabin never gets really hot.
Old 06-24-2007, 06:40 PM
Dealer : Stevens Creek Toyota
2006 Toyota Sequoia
Last Online: 09-29-2008 12:25 AM
maverick_415 is on a distinguished road.
maverick_415's Photo Albums
Mine is weak too. It must just be the way this suv is. I closs the vents I'm not using so more cold here comes out the vents that we are using. Other than that I think we are stuck with weak AC.
Old 06-26-2007, 09:04 PM
Dealer : Toyota of Naperville
2007 Toyota Camry HV 50th Anniversary,
2006 Toyota Corolla
Last Online: 09-02-2009 01:22 PM
9phil9 is on a distinguished road.
9phil9's Photo Albums
The cure is simpler, and considerably cheaper, than you can imagine.
Go the local hardware, or Home Depot type center, and buy some pipe insulation.
It's dirt cheap....like 16 feet for less than $2.50....be sure to get the right size inside, with the self stick edge.
And a small bag of wire ties.
Then insulate the "Cold" line, all the way from the compressor, to the firewall.
You won't believe the difference this cheap fix makes.
But just taking one good look at all that exposed aluminum line, that absorbs heat from the warmest parts of the engine compartment, and you will begin to understand why a lot of that "Cold" refrigerant doesn't make it to the interior.
Old 06-26-2007, 09:58 PM
98xlt's Avatar
2004 Toyota Sequoia
thanks. I'll give it a try.
Old 06-26-2007, 10:16 PM
Johnnny Rock's Avatar
Dealer : DCH Freehold Toyota Scion
2005 Toyota Sequoia
Last Online: 09-22-2009 05:08 AM
Images: 1
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock Johnnny Rock's Photo Albums
I FREEZE inside my Sequoia, I'm not sure of the temp of the air comeing out my ducks but it gets so cold I need to turn the temp up. I will check the temp comeing out my ducks tomorrow. Johnnnny
2004 Ford Lightning (Sonic Blue)
2003 Cobra with LOTS of work : ) (BLACK)
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
Old 06-27-2007, 11:08 AM
98xlt's Avatar
2004 Toyota Sequoia
thanks Johnnny.
Regarding exposed aluminum lines, I'm not seeing much of that under the hood-- a few inches here and there especially near tight bends, most of it has some form of insulation on it already. Maybe I don't know what I'm looking at.
Old 06-27-2007, 04:01 PM
2005 Toyota Sequoia
Images: 1
OK, it's 98 degree's here in New Jersey. It's nasty out hot and VERY humid I checked the temp. coming out my vents and it went as low as 38 degree's useing my laser thermometer. Johnny
1996 Cobra (White)
Old 06-30-2007, 11:30 AM
Dealer : Acton Toyota of Littleton
2006 Toyota 4Runner
Last Online: 10-19-2009 11:19 AM
cheepyankee is on a distinguished road.
cheepyankee's Photo Albums
I cant imagine what Vegas in the summer is like. During our breif 90+ heat waves here, I found you have to "Manage" the system. Plus, you need way more than a 10 mile drive to start cooling down.
Air out: If your rear windows are not tinted, get them tinted. Close your sunroof shade. Get a dash shade. When you first get in, lower all the windows to blow out all the hot air. Even if its 100 outside, its probably 120 inside! As you drive ad the hotter air blows out the vehicle, close the windows.
Controls: Set the temp as low as it will go, crank the fan as high as it will go, and set the vents on fresh air. Once the interior starts getting a little cool, set the vent on Recirculate. This helps it cool down a lot faster.
Vents: If no one is in the rear, shut the rear vents off. Point the dash vents UP, as hot air rises, cold air falls. Set the vents on Face if your feet are not sweaty.
Once you start cooling down, I like to save gas: Turn the temp up to 75, but the fan down to 70%-80%. The compressor works less this way than if the temp was at 65 and the fan was on low.
Old 06-30-2007, 01:49 PM
2005 Toyota Sequoia
Images: 1
I have all my windows tinted and that does help keeping the air cool inside my truck. But I use auto start with my A/C on from the day before and just let the truck sit for 10-15 minutes and when I get outside it's ice cold inside. Johnnny
1996 Cobra (White)
Old 06-30-2007, 11:22 PM
98xlt's Avatar
2004 Toyota Sequoia
thanks guys. we've done everything you suggest including procedures and addtion of tint, windshield reflector etc. We did the tint a year ago and that reduced the heat in the vehicle dramatically.
I finally had the chance to drive ours this weekend and break out the infrared thermometer. Output from the AC standing still does not produce air less than about 50 degrees F (outside air 105F). Started with car in garage, not in sun. Driving for about 5-10 minutes and getting some air thru the radiator gets air output down to 40 degrees, but the vehicle and cockpit is still pretty warm . The IF readings were taken pointing up into the vents on the radio console.
Our older Windstar and Explorer vehicles with dual zone AC in this same LV climate cooled the vehicles completely down within 10 minutes, standing still or driving. Those vehicles did not have any aftermarket tint, either, but did use the windshield sash religiously. I recently picked up a new Honda Pilot and that cools down much quicker than the Seq. also.
I don't know what to think about my options at this point. The general response from the thread would support a dealer's opinion that "this is how they all are."
Old 07-01-2007, 05:03 PM
SUPRALSX's Avatar
Dealer : Reno Toyota
2001 Toyota Sequoia,
- Other - 1989 SUPRA W/LS1
Last Online: 11-04-2009 12:41 AM
Images: 6
SUPRALSX is on a distinguished road.
SUPRALSX's Photo Albums
I LIVE IN RENO AND WE SEE 105+ HEAT WAVES. I FOUND THAT IF YOU HAVE A SUN ROOF OPEN IT ALL THE WAY WITH THE AC ON FULL AND IT COOLS DOWN FASTER BECUASE HOT AIR RISES AND THE COLD AIR PUSHES IT OUT.
Old 07-01-2007, 11:08 PM
Dealer : Roger Smith & Sons Toyota
2002 Toyota Sequoia
Last Online: 10-31-2008 04:03 PM
twoheeldrive is on a distinguished road.
twoheeldrive's Photo Albums
Make sure that the heater control valve is shutting off. It sits in the middle of the firewall at the very top. One hose (the right hand one I think) will be engine temperature hot and the other hose should be no hotter than anything else under the hood. I had to adjust the cable to get mine to shut off all the way.
Old 07-02-2007, 11:06 PM
Dealer : Toyota South
2001 Toyota Sequoia
Last Online: 10-28-2009 04:47 AM
ctedja is on a distinguished road.
ctedja's Photo Albums
My AC is also not cold. I have given up on this. Several trips to dealer did not get me anywhere...
Thanks
Chris
01 Sequoia Limited 4WD - Gibson stainless tip, Lund bug shield, glass break sensor.
95 Avalon XLS - Clarion CD player, MPC bug shield, Weathertech vent visor, ISR mod.
Both vehicles - NGK iridium, Mobil1 synthetic oil, grease & filter, Performance Friction pad.
Old 07-03-2007, 02:12 AM
Last Online: 07-01-2009 12:23 PM
wolfwrangler is on a distinguished road.
wolfwrangler's Photo Albums
I agree. I am very disappointed with the AC system on my wifes 2005 Sequoia. I also agree with 98xlt...because we too had a Ford Windstar it was a 1995, ten years older than the Sequoia and it's AC system puts the Sequoia's to shame! Wait I got one better...my 1985 Subaru Brat blows air so cold you cant keep your hand in front of the vent for more than 20-30 seconds before your hand will feel uncomfortably cold, and No it's not even R12 it is converted to 134a! I finally had my wife take the Sequoia to the dealer, they said the schrader valve was leaking, but I don't think they did anything because I can't tell any difference. I have a fancy high tech digital temperature probe that is very accurate and the lowest reading I could get out of the vents was 55.6 F. I took readings from my car and friends vehicles who's AC was running good and 40 degrees seemed to be the norm or average output at the vents. I saw a thread on here about some heater valve that may not be closing all the way. I will check that out tomorrow. If it's not that, I WILL be going back to the dealer and demand some satisfaction. I've read on here that some of you say your vehicles will freeze you out, so why shouldn't mine work just as well?
2006 Tacoma Air Conditioning drain BEU Tacoma 1 07-28-2006 08:09 PM
2002 Lexus ES300 air conditioning rswinehart Lexus 1 04-26-2006 10:45 AM
Air Conditioning Standard in Double Cab?? skijunk 1Gen-Tundra 3 12-16-2005 03:08 PM
Air conditioning Problem Wolf_Racer 1Gen-Sequoia 2 03-13-2005 08:24 PM
Air conditioning and hot water? 5 Speed Interior & Exterior 1 04-12-2004 02:24 PM
