New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
  1. #1
    Rookie carlinchin is on a distinguished road.
    Join Date
    Jul 2007
    Location
    sacramento, ca
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Question New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
    Hi all, First Post!! I installed an H4 8000k HID Hi/Low Conversion kit on my dads new 07 Sequoia and they look pretty sick! The only problem now is that the foglights wont turn on.... My thinking is that the truck thinks the headlights are on High Beam therefore shutting them off per normal headlight operation. My Dad took it to the dealership and they offered to remedy the situation for $300 which I think is rediculious! Is there anyone out there that has had this same problem and maybe knows of a solution?? Any help would be greatly appreciated, thanks!!!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Rookie ripe911 is on a distinguished road.
    Join Date
    Aug 2005
    Location
    Brooklyn, NY
    Age
    37
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Default Re: New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
    If you can't find the problem, instead of paying the dealer $300, buy another HID kit for the fog lights and run a seperate switch. That way you can put the fogs on when the head lights are off.
  4. #3
    Join Date
    Jul 2007
    Location
    sacramento, ca
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Lightbulb Re: New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
    Wow,...... I hadn't thought of that, thanks for the suggestion! Dang, now it's time to go shopping around again! I would however still like to know what's causing the problem, so if anyone has any ideas, let me know, thanks!
  5. #4
    Supporter bmb408 is on a distinguished road. bmb408's Avatar
    Join Date
    Mar 2002
    Location
    San Jose, CA
    Posts
    103
    Liked
    0 times
    Rep Power
    12
    Are you running a true dual xenon setup with a single ballast and h4 solenoid?
  6. #5
    Join Date
    Jul 2007
    Location
    sacramento, ca
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Question Re: New Hi/Low HID Conversion 07 Sequoia disabled my Foglights!!!
    Yessir, any ideas of whats causing the problem?
  7. #6
    Lurking Member apun is on a distinguished road.
    Join Date
    Feb 2005
    Location
    Norcal
    Posts
    44
    Liked
    0 times
    Rep Power
    9
  8. #7
    Join Date
    Jul 2007
    Location
    sacramento, ca
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the referrence but my HID kit is a dual Hi/Low conversion, sounds like his situation is a little different.
  9. #8
    Join Date
    Feb 2005
    Location
    Norcal
    Posts
    44
    Liked
    0 times
    Rep Power
    9
    Mine is a dual hi/low...uses a solenoid to tilt the bulb to get the high beam.
    Alex
  10. #9
    Supporter sequoiasoon is on the right track. sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    43
    Posts
    1,229
    Liked
    2 times
    Images
    8
    Rep Power
    12
    Not sure how it fits but when I was "playing around" trying to get my fogs to stay on with the high beams, extra voltage somewhere shorted out the ground in the body ECU for the fog lights. Only fix was bypassing and running new wires or replacing ECU. I lucked out and covered tracks very well and after tech spent 1.5 hours trying to place blame couldn't come up with any evidence except bad ground in ECU. They replaced it under warranty. I then ran a separate harness for $35 and they work with parking lights and stay on with high beam. No more playing with the factory wires/computers for me.
  11. #10
    Join Date
    Jul 2007
    Location
    sacramento, ca
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the suggestion, I have a friend who could probably help me with that!
  12. #11
    Rookie Wirth315 is on a distinguished road.
    Join Date
    Mar 2007
    Location
    Cedar Rapids, IA
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    I found that my fogs did not turn on because the vehicle can no longer sense that you lights are on.
    I wired a 20 watt resistor from radio shack into the low beam side and presto my fogs now work as they should.
    Hope this helps.
    Search HID Sequoia and you may see my earlier posts with pics.
    Tom
  13. #12
    Rookie simplexveritas is on a distinguished road.
    Join Date
    Aug 2007
    Location
    Rainy PacNW
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    sorry to bump this thread but the exact samething happened to me. i got this hid conversion (yes, solenoid driven) and the fog lights on the truck went out. i had to call the dealer something like 4 times and they still didn't have a solution.
  14. #13
    Join Date
    Aug 2007
    Location
    Rainy PacNW
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    is this a new toyota related problem? i'm thinking of picking up an IS as well, but i'm half thinking this hid problem is going to plag me some more.
  15. #14
    Rookie square3_5_7 is on the right track. square3_5_7 is on the right track.
    Join Date
    Aug 2007
    Location
    Chesapeake
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default HID Conversion 06 Sequoia
    Is there a HID kit for the '06 sequoia?
  16. #15
    Join Date
    Aug 2007
    Location
    Rainy PacNW
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    yeah, there are plenty online. i picked up this conversion kit from never burn out, but i think you can find an equivalent in lots of places.
  1. Toyota Sequoia Gains New Safety System For 2007
    By TS Support in forum Toyota, Scion & Lexus News
    Last Post: 09-20-2006, 08:31 PM
  2. 05 Sequoia: HID Conversion kit for foglights
    By forourspam in forum 1Gen-Sequoia
    Last Post: 07-20-2005, 06:03 AM
  3. Sequoia Rear Disc Conversion
    By sknaus in forum Suspension & Axle
    Last Post: 05-10-2005, 07:54 AM
  4. HID auxiliary lowbeam photos
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 06:06 PM
  5. Question about stock Tundra Foglights..Help!
    Last Post: 03-28-2002, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
