09-21-2007, 05:49 PM
Last Online: 06-06-2009 08:14 PM
0
Turn Signal Blinking Fast
I have an '01 Sequoia and when I use the left turn signal, it blinks extremely fast. The right signal works normal. Here is some info:
1. The problem was intermittent, but now seems to be permanent.
2. All of the bulbs (front & rear) seem to be working fine.
Anyone know what would cause this?
09-22-2007, 04:08 AM
Last Online: 11-18-2007 03:48 AM
0
Re: Turn Signal Blinking Fast
Are any of the bulbs on your left side seem brighter or dimmer than the rest, if any of them do , change that bulb.
09-22-2007, 06:10 AM
Last Online: 05-18-2008 05:26 AM
0
99.9% of the time that happens it is because of a bad bulb. Compare the right side lights to the left to find out which one.
09-22-2007, 06:18 AM
Last Online: 11-05-2009 06:35 PM
7
Originally Posted by
DMH42b
That's been my experience on on any vehicle I've owned.
2005 reg.cab long bed. A/C, 5 sp auto, cold weather pkg. V8, 4WD, LSD, Desert Sand. 245-75-16 Firestone Destination AT. Extang Trifecta tonneau. Rugged Liner bedliner, Lund vent visors. Classic Accessories back seat gun case, rear breather mod., Garmin Nuvi 200. Clean Breaze rear sliding window screen. Deer head antennae topper.
http://s215.photobucket.com/albums/c...man76_photos/?
09-22-2007, 07:04 AM
0
Gatorman76
It's funny, I've been a machanic (auto tech. whatever you want to call it) for almost 20 years and I see this problem all the time. When I tell someone it's probebly just a bulb, they usualy get a confused look on their face.
I think they are thinking it's going to be some major electrical problem that's going to cost thousands to fix.
09-22-2007, 08:11 AM
Last Online: Today 09:12 PM
9
Check your third brake light.
09-22-2007, 08:27 AM
0
Thanks guys. I knew that this problem was usually the result of a blown bulb, but like I said in my original post, all of the bulbs are working. I suppose I will change one bulb at a time until the problem is corrected.
Thanks again!
09-22-2007, 11:52 PM
Last Online: 11-06-2009 01:31 PM
3
Doesn't the Sequoia have a heavy duty blinker which is unaffected by burnt bulbs?
Z
09-23-2007, 11:22 PM
Last Online: 11-13-2009 10:44 PM
7
I would try replacing the bulbs one at a time. Total cost <$5.
If that doesn't help then I'd look at the relay or a more "exotic" problem.
Or you can get a new relay for $50 first, if you've got money to burn. (If so please send some MY way
-Greg C
07-28-2009, 12:22 AM
Last Online: 09-23-2009 07:40 PM
0
Hi,
I'm having this same issue as you. Turn signal blinking fast but, it's on my right side. Did changing the bulb out work for you?
07-29-2009, 01:34 PM
Last Online: 11-17-2009 01:13 PM
8
If one bulb is out specially the double filament or loose from the socket these could cause the blinking fast. Turn on all your lights and have someone step on the brakes, and check all the lights (front and rear).
07-30-2009, 12:54 PM
Last Online: Yesterday 10:01 AM
4
Turn the 4 way emergency flashers on and compare the left side against the right side for a weak or blown bulb.
Some corner turn signals have more then 1 bulb.
Linear Mode
© Copyright 2009 All rights reserved. TundraSolutions.com.
Other trademarks and brands are the property of their respective owners.
Use of this Web site constitutes acceptance of the TundraSolutions.com User Agreement and Privacy Policy.
Custom vBulletin Skin By
v7web.net
