Limited Slip Diff On Sequoia
+ Reply to Thread
Results 1 to 4 of 4
Thread: Limited Slip Diff On Sequoia
  1. #1
    Rookie hondarider227 is on a distinguished road.
    Join Date
    Sep 2007
    Location
    Temecula
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default Limited Slip Diff On Sequoia
    Hello everyone. I want to add The eaton trd limited slip diff to my wife's Sequoia. I tried to search and see if anyone has used one on the Sequoia and find nothing. I see people have added them to the Tundra's. Any thought or comments?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member el_madmaster is on a distinguished road. el_madmaster's Avatar
    Join Date
    May 2006
    Location
    Gainesville/Fort Myers, FL
    Posts
    503
    Liked
    0 times
    Images
    3
    Rep Power
    8
    Default Re: Limited Slip Diff On Sequoia
    Is your wife's Sequoia a 2wd model? I think this would be redundant if you have the Sequoia in 4wd anyways, as the ATRACS system automatically sends power to the tires that have traction, which I think, in essence, makes both the front and rear axles LSDs.
    As for having the ability to have an LSD in 2wd like the eaton you mentioned, I am not sure. I'm sure someone else here can answer on that soon though.
    1988 Nissan 300zx 5spd 80,000 miles
    1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame shot)
    2001 Sequoia Limited 4x4 182,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
    2006 Suzuki GS500F 6spd
  4. #3
    Supporter sequoiasoon is on the right track. sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    43
    Posts
    1,229
    Liked
    2 times
    Images
    8
    Rep Power
    12
    Do a search and you'll find a couple. One member (u2slo) put in a powertrax and said it made a big difference when he was on the beach etc. I wanted to put the eaton in also but couldn't get a clear answer from them regarding how it effects/causes issues with the ESC if it does. The TRACS system works well as long there is traction and ESC does not cut your throttle. I was in some muddy parking lots and icy hills and would much rather have had some sort of LSD. The TRACS works by applying the brakes to the spinning wheel to transfer torque to the other wheel. Get in the mud or ice and all wheels sin and after about 45 seconds the system stops so as not to burn out the ABS motor and overheat the brakes so you can still stop. 99.8% of the time it's fine but I've experienced the .2% and wasn't thrilled. Even in 4WD I had a hard time starting on an snowy/icy hill that my Dad's 2WD Chevy van was able to start on. Granted it slipped back and forth but churned it's way faster than I did. The throttle just kept getting cut off since the wheel was partially turned and rear wheels were spinning.
  5. #4
    Junior Member SUPRALSX is on the right track. SUPRALSX is on the right track. SUPRALSX's Avatar
    Join Date
    Jul 2007
    Location
    RENO NV
    Age
    28
    Posts
    90
    Liked
    0 times
    Images
    6
    Rep Power
    6
    Well I Thought About The Trd Eaton In My 01. Found Someone Put It In And Had Trouble With The Abs And Traction Contrl. He Said To Only Way To Do It Right Is Eliminate The Abs Sensor Becuase The Dealership Could Not Deprogram The Traction Contrl. Stick With Oem Ftw.
    2001 TOYOTA SEQUOIA 4X4 LIMITED BLACK W/TAN
    1991 TOYOTA PICKUP 4X4 FIBERGLASS FENDERS BED SIDES AND HOOD
    1989 TOYOTA SUPRA(IS NOW GONE)
  1. Limited slip tire scrubbing problem
    By k7qyy777 in forum Tacoma
    Last Post: 08-20-2007, 06:12 AM
  2. Limited Slip Question
    By gussie in forum 1Gen-Tundra
    Last Post: 08-09-2005, 08:28 PM
  3. Rebuild Stock Limited Slip
    By Parshal in forum Engine & Drivetrain
    Last Post: 04-27-2005, 09:15 PM
  4. Got my Limited Slip diff in
    By KLS in forum Engine & Drivetrain
    Last Post: 11-16-2004, 11:21 AM
  5. Power Trax Lockrite or TRD Limited Slip?
    By 01ToyTun in forum Engine & Drivetrain
    Last Post: 10-01-2004, 10:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
