Re: Tried Everything Cannot Open Rear Door
Between the hitch and the spare tire and the lack of clearance they caused I wasn't able to get the bolts to turn. Tried pulling on the cable release one more time, heard a click and was able to open the rear hatch. Removed the locking mechanism and spent the next day trying to remove the lower electrical connection. Finally discovered that you must insert a small nail into the hole in the plug and pry it outward to release the connector. Removed the outside plastic protector and oiled the locking mechanism. I then shut the lock by hand and was unable to get it to rerelease. Played with for another half hour or so and gave up for the day. The next day examined the lock again noticed something was blocking the travel path of the locking arm and pulled out a plastic wire tie. Even though the locking mechanism is completely encased in plastic the wire tie to the top plug is located inside the cover which allowed to to fall in just the right place to prevent the door from opening. Hopefully this help someone else. (I can't be the only one this unlucky?)
