Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Towing Questions", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 01-29-2008, 12:42 PM
Dealer : Ira Toyota of Manchester
2002 Toyota Sequoia
Last Online: 12-22-2008 06:49 PM
bud4ya is on a distinguished road.
bud4ya's Photo Albums
Default Towing Questions
When I am towing my 2 place enclosed snowmobile trailer and 2 sleds do I need to have the OD turned off while towing? If I had to guess on the trailer it is about 500 to 600 pounds, each sled is 500 pounds plus a couple hundred pounds in gear gas etc. So I would say around 2000 pounds that I would be towing. I thought I read on here to always turn OD off when towing but want to make sure. When I have it off on the highway at about 75 MPH the RPMS get right up there. When I turn leave OD on RPMS really drop to normal. Just want to avoid burning the tranny up.
Or should I keep it on and only turn it off going up inclines.
2002 Sequoia LTD 53K Miles.
Thanks
Old 01-29-2008, 02:02 PM
Sequoia311's Avatar
2003 Toyota Sequoia,
1997 Toyota Land Cruiser
Last Online: 01-03-2009 06:24 PM
Sequoia311 is on a distinguished road.
Sequoia311's Photo Albums
Default Re: Towing Questions
I regularly tow a 3000 boat/trailer with my 03 Sequoia and I always turn off the OD, even if I'm on the interstate running 75+. I used to tow the same boat with a 1500 Dodge Ram and never turned off OD, and it kept shifting gears and messing with the tranny even at slower speeds.
Old 01-29-2008, 04:11 PM
2002 Toyota Sequoia
I had two Expeditions and towed many many thousands of miles and never turned off OD. I have not towed a lot with the Sequoia but it does not nearly tow as well as the Expedition did. Oh well it will last longer I guess. So I guess the answer is turn OD off when I am towing the trailer and sleds. Boy that really kills the MPH even more .
Old 01-30-2008, 01:22 PM
williamZ's Avatar
Dealer : Jack Safro Toyota Scion
2003 Toyota Sequoia
Last Online: 11-15-2008 09:35 AM
williamZ is on a distinguished road.
williamZ's Photo Albums My eBay
Last time I looked in the owners manual I don't remember it saying to turn OD off when towing.
Chris Williams
Old 01-30-2008, 03:06 PM
Dealer : Kings Toyota
2001 Toyota Sequoia
Last Online: 12-19-2008 09:27 AM
guyaverage is on a distinguished road.
guyaverage's Photo Albums
I towed a 3000 lb. boat about 400 miles round-trip 5 times last summer with O/D off, for the sake of not nuking the 4th gear planetary, a problem that seems to plague the early tranmissions. Averaged about 12-13 mpg even with the a/c on.
(I towed the same boat with my '95 V-6 4Runner and averaged a steady 11 mpg with the O/D on. Couldnt use the a/c, not enough power to do both the boat and a/c at the same time!)
For the sake of the 4th gear planetary, I would leave O/D off. The few extra hundred rpm's are not going to hurt this engine at all, the gas mileage difference will not be that much, its not that much noisier, and the extra torque is nice. I'm sure many with the early transmissions tow with the O/D on and have lots of miles doing it this way without problem, but since I have an '01 with a known weak spot I'm not willing to take the chance for such a small gain.
Old 01-30-2008, 03:29 PM
Dealer : Toyota of Waterford
Last Online: 01-30-2008 03:58 PM
ToyotaServiceManager is on a distinguished road.
ToyotaServiceManager's Photo Albums
It is only necessary to turn off OD if the transmission is hunting and searching for the correct gear (shifting up and down constantly and can't decide which gear to use) as this will cause overheating. as long as this is not the situation then leave the OD on and allow it to take care of itself even when towing.
Old 01-30-2008, 07:17 PM
2002 Toyota Sequoia
Thanks All
My neighbor said the same thing tonight if it is not searching for gears leave it on. It was sorta a catch 22 where I do not want to fry the tranny or over work the engine with OD off. In reality it is only about 2,000 pounds so that is not that much weight.
Old 01-31-2008, 05:05 PM
Dealer : Ron Tonkin Toyota
2008 Toyota Sequoia
Last Online: 04-25-2008 04:56 PM
crashing_sux is on a distinguished road.
crashing_sux's Photo Albums
It depends on the tranny, but on my 2002 4runner hunting for gears wasn't the issue, the problem was if you left the OD on you would get MUCH better mileage towing (went from 11mpg to 15mpg) but it would unlock the torque converter and if you weren't careful you would overheat the tranny from running 10 minutes with the torque converter unlocked. It never bothered to downshift to third, just kept cruising in 4th with the torque converter unlocked. Turning off the OD not only caused it to downshift to 3rd, but it allowed the converter to lockup which is critical. You can tell when the torque converter unlocks if you watch the tachometer carefully.
Bookmarks
