Can anyone tell me why the rear window, defrost and wiper no longer work on my '05 ltd? The dealer has said they have no idea and would have to take apart the rear hatch. Sounded expensive and also potential for future trouble. I have checked all of the fuses. When trying the rear window you can hear the motor for a 1/2 second then nothing.
This may be dumb, but are you sure that the window is 100% closed? If it is at all open it will deactivate all of those. I'm not sure if it affects it, but the driver's passenger window lock button might deactivate the rear window too... tho i am not sure on that.
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
We have tried everything. The window stopped working several months ago. It doesn't go up or down using the key in the door, the remote or the button on the dash. I have tried all the tricks that have been posted and have pulled all the fuses...nothing worked. I have rearranged the rear wiper blade to make sure it is in the correct spot.
Is there an easy way to access the inside of the hatch? I can't see any connectors to pull off the inside panel.
It sounds like it should be a fuse since the wiper, defrost and window doesn't work but I can't find which fuses it may be.
Poor design on Toyota's part. If one thing doesn't work make them all not work????
Same happened to me under warranty. Dealer replaced the window motor and all is well.
Not reallya poor design..........you don't want or need to use the wiper or defogger when the window isn't closed. If the motor malfunctions or didn't close the window completely, then those other things won't work.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
Hmmmmmm, I just change my battery in my '05 seq ltd and lost all the same stuff, but have assumed I blew a fuse when changing the battery. I haven't checked to see if the window works. Here in Minnesota it is too ffffcold to role any windows down. But I have been missing the wiper in the sloppy conditions. I've got 65K, doubt warranty is going to do me any good.
I had the exact same issue with my '05 Limited Sequoia. None of the 3 worked (wiper, window, defrost). I assumed and really couldn't see how it could be any else but a fuse, but after following several other threads pertaining to this, I was able to fix on my own by removing the back panel of the tailgate, disconnecting/reconnecting all wiring, and tapping on the motor several times. I was incredibly skeptical about doing this, but had nothing better to do at the time and did not want to pay a ton of money without having to, so I got after it. I got a interior panel tool from the local auto part store and followed the TSB EL007-06 (Back Door Power Window Inoperative). It took about 45 minutes...took my time (live in Iowa, so it's cold as hell here too). Once I was finished, my rear wiper started running as soon as I turned the key on, as I must have left it in the ON position prior to starting. Now all 3 work. In my opinion, I think it has something to do with the cold weather we live in freezing the grease, etc in the motor if the window isn't used very often (hence the tapping on the motor). The remaining options must be connected to that window motor as well, which is why they quit working once the window does. I never thought in a million years it would work, but it did. Now that I think about it, this same thing happened to me when about a year ago when it was still under warranty and I took it in when getting the oil changed. They told me some story about my connections and ECU, and that they replaced it, etc...but still had problems. Knowing what I know now, sounds like BS. Give it a shot. The paneling comes off much easier than you think.
Had the same problem; here's what fixed mine. It appears that the window motor some how got into a bind. I removed the rear panel. Remove screws from rear hatch access panel. There is a plate with four screws that hold the window motor. I loosened these screws and lightly wiggled the panel while my son was inside pressing the switch in the down position. The widow and wiper now works! Hope this helps.Wonder what the dealer would have charged for such a fix?
Thanks Nevans3! How nice to have the actual TCB. I have an 05 SR5 with the EXACT same problem. I will follow the Tech. Service Bulletin you posted tonight.
penntl and evans3 were right. i took off all the paneling and unscrewed the rear window motor just enough to jiggle it a bit and the retightened. It works like a charm. My rear wiper works now as well. No new motor needed. THANKS!
