Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Hitch Update", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 05-09-2008, 06:13 PM
Dealer : Sun Toyota Scion
2006 Toyota Sequoia
sequoia_man's Photo Gallery sequoia_man's Photo Albums
Last Online: 07-21-2008 09:17 PM
sequoia_man is on a distinguished road.
Default Hitch Update
I ended up getting a used OEM hitch off ebay for 100 dollars. It didnt come with any hardware so im wondering if i should get the toyota bolts or just get some from the hardware store? Also, what is my next step with the wiring?
Old 05-09-2008, 11:21 PM
tinik's Avatar
love to travel
Dealer : Germain Toyota Scion of Sarasota
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
tinik's Photo Gallery tinik's Photo Albums
Last Online: Yesterday 08:12 PM
tinik is on a distinguished road.
Default Re: Hitch Update
Hitch is easy to install, and most of the sequoia (as many as i've seen) are already prewired. If needed, I can swing by in my sequoia, and you can take a look
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei
2001 Toyota Tundra SR5 4x4 w/ lots of miles on it!
Old 05-10-2008, 03:28 PM
2006 Toyota Sequoia
Thanks. What part of Sarasota are you in? I am in Lakewood Ranch. Im going to get the manual out and do some more research into wiring.
Old 05-11-2008, 09:13 AM
tinik's Avatar
love to travel
there is no need for you to look on that.
I live close to laurel rd.
If you look on a drivers side under your car, you will see to wire plugs (you can buy a connector with plugs in discount auto parts)
on a drivers side where parking brake located, there is white plug, that one is made for brake controler.
I you need, i will take pictures later (my friends 2005 Sr5 came prewired, that is how i know)
Old 05-11-2008, 11:03 AM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
el_madmaster's Photo Gallery el_madmaster's Photo Albums
Last Online: 07-18-2008 11:26 PM
el_madmaster is on a distinguished road.
Quite a few owners around here from SW Florida.
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
Old 05-12-2008, 06:48 PM
2006 Toyota Sequoia
Tinik,
Can you snap some pics for me? I looked by the parking brake but didnt see any white plugs. I also looked under the car and didnt see any wire plugs.
Old 05-13-2008, 07:56 AM
tinik's Avatar
love to travel
here you go
Old 05-13-2008, 08:29 PM
2006 Toyota Sequoia
Thanks a ton. I didn't look yet but im sure they are there somewhere.
Old 05-13-2008, 08:43 PM
tinik's Avatar
love to travel
they are there (with a dummy plug in them, so they don't get dirty)
another thing is, you might need a tow computer (located very close to glove box) - but i think - most likely you have it.
Old 05-14-2008, 04:06 PM
2006 Toyota Sequoia
Have you heard of needing a relay? Someone on another forum mentioned it.
Old 05-14-2008, 06:35 PM
2006 Toyota Sequoia
Good news..I found the brake controller wire under the left kick panel. It was pretty far back and taped to some other wires. I think I found the trailer hook up under the frame. In your pic it shows 2 plug ins. One grey and one black on top of each other. Mine has the grey one but i don’t see either one of the wires that go into the black connector. Any ideas? I think I am just going to pick up a cheap 4 pin, flat connector to pull the wave runner. I will eventually need a 7 pin to tow a travel trailer but cant find anything OEM for cheap.
Old 05-29-2008, 07:56 PM
Dealer : Toyota Scion of Melbourne
2005 Toyota Sequoia
matt325's Photo Gallery matt325's Photo Albums
Last Online: 06-27-2008 05:11 PM
matt325 is on a distinguished road.
I am looking at a used 2005 Sequoia without the factory tow package.
The dealer has installed a hitch, but only a 4-pin connector connected into the factory tail light harnesses.
Trouble is, I *need* the 7-pin connector so I can use trailer brakes. The dealer isn't really sure if the vehicle wiring harness is there to support a 7-pin.
Can anyone confirm that a 2005 Sequoia *without* the factory tow option does indeed have the supporting wiring harness, including the connector up near the driver-side kick panel?
I would like to be able to buy a 7-pin harness/connector to replace the 4-pin one and a brake controller and both be plug-and-play. I *don't* want to have to run wires from the front to rear and any associated relays and brake pedal interfaces.
Thanks
Old 06-11-2008, 10:03 PM
Tripower455's Photo Gallery Tripower455's Photo Albums
Last Online: 07-13-2008 12:05 PM
Tripower455 is on a distinguished road.
How is the 4 pin wired into the factory wiring? Does it use a powered adapter?
Old 06-16-2008, 08:25 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
jliltd's Photo Gallery jliltd's Photo Albums
Last Online: 07-07-2008 12:55 AM
jliltd is on a distinguished road.
I have a 2001 Sequoia that came from the factory with flat-4 connector on the OEM trailer hitch. I too needed to add 7-pin receptacle and trailer brake controller. I purchased a 7-way 4-way conversion kit complete with front-to-rear wiring harness from etrailer, p/n ETBC7 (Brake Controller 7 & 4 Way Installation Kit - 10 Gauge ETBC7 : Trailer hitch bike rack and trailer hitches - etrailer.com). All I had to do in the rear was plug the kit's 4-way male connector to the Sequoia's factory 4-way female connector and tuck that way neatly up under the frame. Then all that was missing was the two wires that were run up front with the included jacketed wire. One wire comes from the brake controller and the other provides ACC power (via key-switched relay) in case your trailer has dome lights, etc. The rest of the install included a Tekonsha Prodigy brake controller (from my Tundra where I upgraded to a Tekonsha P3). I tied the controller's signal input wire to my break pedal switch after reading posts in the towing forum on TS. I also made sure to tie the break controller power and ground directly to the battery as specified by Tekonsha.
Speaking of, the towing forum on TS has a lot of great information for wiring this up. That's where I learned to relay the ACC power circuit to the trailer and also install a 30A circuit breaker off the power lead from the battery.
Old pilot's proverb: "Never fly the A Model of anything..."
Old 06-22-2008, 07:36 PM
2005 Toyota Sequoia
Can anyone with a factory tow package confirm the presence of relay P/N 9098702012 ?
Even better, would be a picture of the relay installed in the fuse panel.
My dealer did something similar to the post above wiring a flat-4 into a 7/4 with additional wires, including a 30A circuit breaker off the power lead from the battery.
But the right turn signal and brake lights are not working properly on my trailer. Running lights and the left signal are working. They hooked up a tester to the flat 4 connector and it seemed to indicate everything was fine.
They say its the trailer, but in trying to diagnose, I looked for the relay and don't see it, or, know if it is really needed.
Thanks.
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography
