Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Power Steering Fluid Change", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 06-08-2008, 08:07 PM
Ray Ray is offline
Dealer : Classic Toyota Scion
2001 Toyota Sequoia
Ray's Photo Albums
Last Online: 10-09-2008 06:12 PM
Ray is on a distinguished road.
Default Power Steering Fluid Change
I have an 01 Sequioa Limited 4WD. Anyone have the DIY for the power steering fluid change? What power steering fluid should I use? Can I use the power steering fluid that can be purchase at a local autopart stores (valvoline, preston)? Owners manual calls out Dexron II or III. I was thinking of using a turkey baster to suck the fluid at the reservoir.
Old 06-09-2008, 04:17 PM
mfinley's Avatar
Dealer : Metroplex Toyota
2004 Toyota Sequoia
mfinley's Photo Albums
Last Online: 10-08-2008 04:48 PM
mfinley is on a distinguished road.
Default Re: Power Steering Fluid Change
Turkey baster works well. Buy any good quality DexIII and you will be fine.
Old 06-09-2008, 08:02 PM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
mcmatt's Photo Albums
Last Online: 07-21-2008 08:56 PM
mcmatt is on a distinguished road.
Jack up the front wheels with jackstands and block the rear wheels. I use synthetic Mobil 1 ATF just for grins. Disconnect the return (top) hose to the resevoir. Use a tubing adapter and attach a long piece of hose that you can run down to a drain pan.
Start the engine and have someone turn the wheel back and forth a couple of times while you keep the resevoir full. The ATF will get pumped through the resevoir FAST. Be ready. The pumping will stop when the wheel is centered. Once you have flushed with a qt or so, stop the engine. Then reattach hose and fill with ATF. You are done. The hardest part is jacking it up and routing the hose, the rest is easy. Good Luck!
