Old 06-14-2008, 05:39 AM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
Last Online: 10-30-2009 11:36 PM
mcmatt is on a distinguished road.
mcmatt's Photo Albums
Default Window glass popping noise fix
Just an FYI. I was having a horrible popping noise coming from the glass on the drivers side whenever the window went up or down. It sounded like the glass was about to break.
I took the door panel off (fish the switch panel through the hole so you can leave it attached and use it.)
Turns out the glass is mounted to the regulator with only two small 10mm bolts. They were both loose. I used a little loctite and tightened them and the window is perfect again.
The point is.... if you are in the door for any reason, you might want to check the bolts, tighten them and/or give them some threadlocker.
Old 06-16-2008, 06:39 PM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
Last Online: 07-26-2009 07:56 PM
el_madmaster is on a distinguished road.
el_madmaster's Photo Albums
Default Re: Window glass popping noise fix
Hmm I might have a very slight case of this. Do you know if you have to remove the entire door panel to replace the speaker, or can you j ust pop off the speaker cover?
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
Old 06-16-2008, 09:57 PM
mcmatt's Avatar
2001 Toyota Sequoia
Yes you have to remove the whole door panel. Easy though. Open the door and from the left to right (on drivers side) there are:
2 clips push in and pull out, 1 screw in armrest, 1 screw in handle, remove bezel by prying above and below handle, 1 screw under a cap up front, then put a big taped flathead under the bottom edge and pry and pull. Unplug 2 wiring harnesses and it is off.
Old 09-11-2008, 08:00 AM
Dealer : R & H Toyota
2001 Toyota Sequoia
Last Online: 09-11-2008 08:02 AM
selewi3 is on a distinguished road.
selewi3's Photo Albums
Thanks guys. My driver window bolts must have come loose yesterday. Going to use your input to fix it today. Again, thanks.
Old 05-03-2009, 07:24 PM
Last Online: 05-03-2009 07:24 PM
tocjonah is on a distinguished road.
tocjonah's Photo Albums
Guys, you just saved me $300 and a lot of time, thank you for posting this.
Old 05-04-2009, 04:03 PM
Dealer : Downtown Toyota Scion of Spokane
2001 Toyota Sequoia
Last Online: 11-07-2009 01:19 AM
GeCJ7 is on a distinguished road.
GeCJ7's Photo Albums
I have this same kind of crunching noise on my 01 when the window goes down. Glad that there is a way to fix it! I will try it this weekend. Thanks for the post!
