Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "02 Fuel filter", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 07-17-2008, 12:07 AM
trackzonie's Photo Albums
Last Online: 09-28-2008 11:07 PM
trackzonie is on a distinguished road.
Send a message via AIM to trackzonie
Default 02 Fuel filter
The line leading from the fuel tank to the fuel filter seems to be held on with a red clip. The front has a threaded fitting. The filter itself has a slim fuel line for the inlet.
How does one remove the red clip? Just pull off and slide onto the new filter? Or does it somehow spread apart and then snaps back on?
Thanks
Old 07-17-2008, 09:01 AM
Dealer : Ira Toyota of Manchester
2002 Toyota Sequoia
bud4ya's Photo Albums
Last Online: 08-12-2008 12:31 PM
bud4ya is on a distinguished road.
Default Re: 02 Fuel filter
When you get your answer can you post back or PM me on how hard this was to do? I have been thinking about doing this myself if it is fairly easy. Any pics on the location of the fuel filter? If not I will follow the line starting at where you fill it.
Thanks
Thanks
Old 07-17-2008, 08:15 PM
For the 2002 it is along the frame rail by the driver's side door.
Old 07-17-2008, 08:25 PM
2002 Toyota Sequoia
Thank you. Is it an easy DIY job? Like just it just snap out and new one snap in sorta speak?
Thanks
Old 07-18-2008, 12:09 AM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
mcmatt's Photo Albums
Last Online: 07-21-2008 08:56 PM
mcmatt is on a distinguished road.
The clip spreads apart and then you have to pry it off. It has 3 places where it holds. Changing the whole bracket is a bit frustrating. It is hard to get to all the bolts. I take the filter out of the strap and just replace it. It has a specific orientation/detents.
It is a whole lot easier the 2nd time you do it
Old 07-18-2008, 07:51 AM
Dealer : Rolling Hills Toyota Scion
2003 Toyota Sequoia
M in KC's Photo Albums
Last Online: Yesterday 02:10 PM
M in KC is on a distinguished road.
I'm sure my second time will be quicker as well. mcmatt is right twist the red clip and pull it off. I left the filter in the strap as I recall both while removing and re-installing. I felt it gave the fitting more resistance and I didn't have to fight the filter moving around. But to each their own. I will consider his method the next time I change mine. I only found the filter at the dealership with bracekt/strap assembly. It's about a 30 minute job. Take the pressure off the lines before you start the filter removal by running the engine with the fuel pump fuse removed. This won't completly evacuate the fuel line but it helps. Have some rags or a small catch pan handy as some residual gas will still be present. Glasses or goggles are a bad idea either. Once installed replace the fuel pump fuse and check for leaks. If none you're golden and Bob's your Uncle.
Old 07-18-2008, 10:39 AM
Thanks
I'll do it this no NASCAR weekend.
Old 07-18-2008, 01:41 PM
Question Re: 02 Fuel filter
Does anybody know which fuse controls the fuel pump? I found several listed for the fuel injection system but nothing specifically identified in the manual as for the fuel pump
Old 07-19-2008, 09:56 PM
Way easy. Decided to keep the original support on the frame and just swap filters.
Broke the front fitting loose with a 19 and 14 mm set of wrenches. Used a small socket to loosen the clamp that goes around the filter. Used a small thin standard blade screwdriver to loosen the red clip. Pop out the filter. Take the hose support off the old filter and place on the new filter. Reinstall. Took ten minutes and spilled about 2 ounces of gas.
Old 07-23-2008, 11:57 AM
Dealer : Scott Clark's Toyota City
2002 Toyota Sequoia
Bigtoy4u's Photo Albums
Last Online: 10-01-2008 09:17 PM
Bigtoy4u is on a distinguished road.
Which fuse did you disconnect?
Old 07-23-2008, 10:08 PM
I didn't. One of the big fuses in the box under the hood was marked as the fuel pump though . I opted not to pull the fuse. I hadn't driven it for 12 hours, opened the fuel cap and disconnected the line. At MOST two ounces spilled out. The tank was low, maybe three gallons left in it and the driveway has a slight incline
