Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Toyota 4-pin to 7-pin adapter ???", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 07-31-2008, 03:20 PM
2004 Toyota Sequoia
chrono111's Photo Albums
Last Online: 07-31-2008 04:26 PM
chrono111 is on a distinguished road.
Default Toyota 4-pin to 7-pin adapter ???
Hello, I'm going to install a brake controller and have the tow package. But it doesn't have a true 7 pin harness, just and adapter that connects to the 4 pin. I was told that wouldn't work? Kind of confused. Anyone with a brake controller give me some insight?
Old 07-31-2008, 05:45 PM
Dealer : Rolling Hills Toyota Scion
2003 Toyota Sequoia
M in KC's Photo Albums
Last Online: Yesterday 05:57 PM
M in KC is on a distinguished road.
Default Re: Toyota 4-pin to 7-pin adapter ???
First off what kind of brake controller do you have that you are trying to install? Unless I'm completely missing the boat the brake controller mounts inside your vehicle and if it's like my '03 the harness connector is behind the kick panel by the driver's left foot. Most modern brake controlers will have several harnesses to accomidate many makes and models.
I installed a Prodigy brake controller on this vehicle a couple of years ago and it was a great upgrade followed by rear airbags this spring. Another lead pipe winner. The brake controller was a simple plug-n-play affair as I bought the appropriate adapter for my vehicle from Prodigy rather than splicing wires.
Old 08-06-2008, 01:59 PM
Dealer : Jack Safro Toyota Scion
2004 Toyota Sequoia
outbid81's Photo Albums
Last Online: 10-06-2008 01:25 PM
outbid81 is on a distinguished road.
Are you sure you have the tow package and not just an aftermarket hitch and wiring? I also have an 04 with a factory hitch and 7-pin plug. Just to the left of the spare tire there should be two gray connectors that go straight to the trailer harness. If your harness has only four wires, you only have light control. There wouldn't be any kind of adapter that would work with the factory's pre-wiring for the brake controller. If you do have those two connectors, you probably only need the factory harness from your local dealer.
