Old 08-12-2008, 01:05 PM
Dealer : Power Toyota Irvine
2005 Toyota Sequoia
Last Online: 01-20-2010 09:30 AM
iamanirvanafan may have some regrets.
iamanirvanafan's Photo Albums
Smile Several Problems can any 1 help out? On Nav, rear window and fuel
I have an 2005 lmted Sequoia.
1st problem is my rear window will not go up or down from key fob and from inside the cabin. Could it be a fuse? Where would I look for it if it was? Or could it be another problem. I did replace the rear latch handle which was an easy fix. When I did install it the back window did work for a few months.
2sd problem is navigition overide. I have tried this and does not work:
Menu - Volume
Tap top left, bottom left, top left, bottom left continue about 3 times until the program screen shows up
Then click and HOLD override until it beeps
Then click back,
You have to do this everytime the vehicle is started
Any Ideas to override nav while driving?
And now the 3rd problem and last one is fuel. I have owned my Seq. for two years now and when I used to top of on gas my over the head console would show me 320 miles on a tank. Now when I top off on gas it is showing me about 280 and now starting to get that on a full tank? Any ideas why.
Thank you for taking the time to read this.
Old 08-12-2008, 01:14 PM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Yesterday 08:14 AM
czechm8 will become famous soon enough. czechm8 will become famous soon enough. czechm8 will become famous soon enough. czechm8 will become famous soon enough. czechm8 will become famous soon enough. czechm8 will become famous soon enough.
czechm8's Photo Albums
Default Re: Several Problems can any 1 help out? On Nav, rear window and fuel
#3 - DTE (distance to empty) is based on average MPG. Reset your Average MPG and the DTE will change.
Set the display on Average MPG, then hold down the far left and far right buttons at the same time and it will re-set the average and begin a new average going forward.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. HAT tweeters, Scanspeak mids and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
Old 08-12-2008, 06:07 PM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: 03-18-2010 12:08 PM
Andy4 may have some regrets.
Andy4's Photo Albums
try this posting for your window problem.
look at the TSB.
Rear Window, Defrost, Wiper not working
Your MPG could have gone down with the introduction of ethanol to the gasoline.
Straight ethanol has about 60% of the "power" gasoline has.
The E15 is 15% ethanol, and you can expect to loose a few MPG. It reduces emissions, you use more fuel to go the same distance therefore pay more federal and state "gasoline tax".
Using a blend greater then E15 will destroy your engine.
The ethanol also absorbs moisture and cause some problems where it is humid.
Ethanol from corn is one of the BIGGEST rip-offs and sellout the Federal Govt has done recently, the next one will be a windfall profit tax on "big oil" and giving us a $1000 .
Old 08-12-2008, 09:28 PM
Dealer : Miller Toyota
1995 Toyota T100,
2001 Toyota RAV4
Last Online: 03-20-2010 10:08 PM
95t100 may have some regrets.
95t100's Photo Albums
I'll 2nd the recommendation to download the TSB for the rear window. This last weekend I removed the stopper (see TSB) and window, defroster and wiper all now work fine. Cost was nothing and time spent was maybe 45 minutes, mostly just being careful when removing the panels.
