Old 08-28-2008, 02:30 PM
Dealer : Folsom Lake Toyota Scion
2005 Toyota Sequoia
Last Online: 08-28-2008 03:38 PM
2005seq is on a distinguished road.
2005seq's Photo Albums
Unhappy How do I replace the passenger side view mirror unit?
Hi,
I recently backed out of my garage and hit my passenger side view mirror. The mirror is still in once piece, however the whole unit is dangling from the car's frame.
How should I go about either fixing it, or replacing it with a new unit? Is it an easy task that I can complete myself or do I need to seek professional help?
Thanks in advance!
Old 08-29-2008, 12:19 AM
Dealer : Longo Toyota
2008 Toyota Sequoia
Last Online: 11-13-2009 10:01 AM
rguyekaw is on a distinguished road.
rguyekaw's Photo Albums
Default Re: How do I replace the passenger side view mirror unit?
typically you need to remove a plastic piece or two on the inside of the door - just behind the mirror. Then you'll typically see three bolts that hold the mirror in place. Then unplug the wire harness. I replaced a mirror assembly on my Honda Accord and it cost about $170. I'll bet the Sequoia mirror is as least $300
Old 01-03-2009, 11:38 PM
Last Online: 01-03-2009 11:43 PM
as81162 is on a distinguished road.
as81162's Photo Albums
I swaped out several on a Tundra--I think they're the same design. You have to first remove the inside door panel (which is a lot easier than you might expect). If you know what you're doing, it only takes 10 minutes.
After that, the above post is exactly right--three bolts and disconnect the wire harness.
This post was a few months ago, so I assume you've got it all figured out by now. If not, let me know.
Tags
mirror , passenger , replace , sequoia , side view
