Re: Crankshaft Pulley Removal
That way works, but I do have a friend with new Front Teeth because the extension against the frame slipped off, he tried to hold it (not smart)..... becareful when doing it this way. It can send the socket thru the radiator ( been there done that) if it accidentally comes off.
25 yrs with TOYOTA
