Re: Transmission thunk....not driveshaft
Yes, it's only for 2wd's.
We have also found "U" joints that were tight and when felt with your hands,they feel "NOTCHY". They are smooth when moving and then there is a small hard spot in their movement, but this is not a Toyota fix, just what we have found too. We replace the "U" joint, usually it is the rear most joint. Sometimes it works and other times it doesn't. We also clean the part of the shaft with the splines and remove any rust or debris and grease the splines with a teflon grease, this helps too.
25 yrs with TOYOTA
