Old 12-15-2008, 09:11 PM
Ray's Avatar
Ray Ray is offline
Dealer : Classic Toyota Scion
2001 Toyota Sequoia
Last Online: 11-17-2009 01:13 PM
Ray is on a distinguished road.
Ray's Photo Albums
Default Help: P0420 code
I have an 01 Seq. Limited, 128K miles. Definition P0420 - catalyst system below threshold bank 1. Any idea? O2 sensor? Cat? Bank 1, driver/passenger side? Before/after cat?
My MIL: P0420
Pending: P0420
Freeze frame data below
RPM: 1344
Load value: 32.9%
Coolant temp: 179 F
Intake air temp: 51 F
Short term fuel trim 1: 0.0%
Long term fuel trim 1: 14.8%
Short term fuel trim 2: 0.8%
Long term fuel trim 2: 11.7%
Short term fuel trim 3: -100.6%
Long term fuel trim 3: -100.6%
Short term fuel trim 4: -100%
Long term fuel trim 4: -100%
Speed: 21 mph
Fuel system 1: closed
Fuel system 2: closed
Old 12-19-2008, 11:27 AM
RogueRider's Avatar
Get off the pavement!
Dealer : Toyota of Dallas
2001 Toyota Sequoia,
2007 Toyota Camry
Last Online: 11-13-2009 07:34 PM
Images: 9
RogueRider is on a distinguished road.
RogueRider's Photo Albums
Default Re: Help: P0420 code
Bank 1 is left (driver side). I don't know how to read the freeze frame data to isolate the problem, sorry. The P0420 DTC could be the cat, O2 sensor 1 or O2 sensor 2. I had the same code and it turned out to be the cat but you'll want to make sure its not an O2. My friend owns an auto repair shop and he put the #1 and #2 O2 sensors on the diagnotic screen while we drove around (I drove, he watched the screen) to determine that the O2 sensors were functioning. The O2 sensors were not dead so we replaced the cat. Another way he troubleshoots the problem is to move the O2 sensors to the other bank and see if the DTC switches sides. Not a simple task but if you don't have a diagnotic tester to look at O2 wave forms.... PM me if you want more detail on the diagnotic waveforms.
Old 12-26-2008, 02:02 AM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
2004 Toyota Sequoia,
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 10-17-2009 04:39 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
Can you post the sensor values for the oxygen sensors?'
Fuel trim for 3 and 4 look WAY off. It's saying that 3 and 4 are running EXTREMELY rich.
You have three main causes for the code, the H02S, the catalytic converter, or a leak in the exhaust. Judging by your fuel trim, it's most likely in the sensor.
Has any other work been done on the vehicle?
It might be time to get a real diagnosis done on it though, one way or the other something is not right and it could end up being very bad. If it's leaning out the engine that much, it could damage it.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
Old 12-26-2008, 10:13 AM
Ray's Avatar
Ray Ray is offline
2001 Toyota Sequoia
Ray's Photo Albums
Thats all the data that shows on my OBD scanner. Due to mileage I think I will just change my O2 sensor. Also, there was no work done in the vehicle.
Old 12-31-2008, 01:17 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: 11-04-2009 11:46 AM
jliltd is on a distinguished road.
jliltd's Photo Albums
Good idea. Replace all 4 O2 sensors if you want to shotgun it (I assume you will do work yourself). It is extremely rare for a catalytic converter to go bad within 200,000 miles and they are very expensive. And O2 sensors in these motors are known to go bad with regularity. I have been to two different dealers who swore the cat needed replacing when it was only an O2 sensor after all.
If you want to save some time/money then just replace the two O2 sensors for Bank 1. Stick to the Denso brand sensors (OEM supplier to Toyota). I think I bought two from sparkplugs.com that were OEM and two more that were aftermarket Denso. Don't buy Bosch sensors for a Toyota no matter what compatibility is claimed by Bosch.
Here's a post I made about replacing the O2 sensors on an '01 Sequoia with a lot more detail:
Oxygen Sensor Part Number and Location
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
Old 01-03-2009, 12:33 AM
Ray's Avatar
Ray Ray is offline
2001 Toyota Sequoia
Ray's Photo Albums
I will doing the work myself. Just receive Denso O2 sensors (manifold and after cat), and catalytic converter (bolt on, one piece, flange, pipe) for Bank 1. I will just do Bank 1 for now.
Old 01-03-2009, 01:52 AM
JBH1989's Avatar
Why are you replacing the cat?
Old 01-03-2009, 07:52 AM
jliltd's Avatar
I'm with JBH on this one. Keep the new cat in the box so you can return it. If after you change out the O2 sensors and clear the codes you may well find you don't really need to change the cat, saving lots of effort and money.
Old 01-03-2009, 07:59 PM
Ray's Avatar
Ray Ray is offline
2001 Toyota Sequoia
Ray's Photo Albums
I replace the cat because when I tested the O2 sensors on the car with a scan tool and bench tested them, both sensors are working properly. I'm keeping the cat for at least two weeks, about 400 - 500 miles running the new cat. I bought the parts at rockauto, cat with pipe $240.
Old 01-03-2009, 10:26 PM
JBH1989's Avatar
Are you basing it on voltage range of the sensors? They did exceed 800mV and below 450mv?
I wouldn't open the new cat (can't return an open cat usually) unless I knew absolutely for sure that it was the cat and not the sensors (ie run the new sensors for a few drive cycles and see if P0420 comes back). Then again I hate shotgunning a vehicle with parts.
Cat's don't commit suicide--they are murdered. They don't just go out, either something was really bad that you ignored (like a flashing CEL but you didn't post any misfire codes). Any sort of catalyst damaging event would have triggered a CEL and set multiple DTCs. H02Ss on the other hand do go bad with age routinely--the heater more often than the sensor in my experience.
Old 01-04-2009, 02:43 AM
Ray's Avatar
Ray Ray is offline
2001 Toyota Sequoia
Ray's Photo Albums
I used a scanner (borrowed) that can read O2 sensors waveform and the bench test using a blow torch the tip of the O2 sensor and monitor the output voltage. Also, I had that rotten smell from the exhaust.
I didn't have any misfire but I had an exhaust manifold leak for awhile that I ignore (fix). Thats the only code (P0420) that ever appears since I own my vehicle.
Old 01-04-2009, 07:20 PM
JBH1989's Avatar
Did the H02S peak over 800mV and below 450mV?
Old 01-05-2009, 08:44 AM
Ray's Avatar
Ray Ray is offline
2001 Toyota Sequoia
Ray's Photo Albums
The HO2S peak above 800mV and below 450mV.
Old 01-05-2009, 07:36 PM
JBH1989's Avatar
Okay, just checking because you can get a good sensor waveform with bad sensors.
Old 01-08-2009, 04:08 AM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Dealer just replaced my cat for the same code. Had gone in before and they replaced the O2 sensors but code showed up again. Covered under factory warranty for emmisions.
