  #16 (permalink)
Old 11-04-2009, 12:49 PM
nivlak's Avatar
2006 Toyota Tundra,
- Other -- 2002 R1
Last Online: 11-24-2009 02:03 AM
nivlak is on a distinguished road.
nivlak's Photo Albums
Default Re: Lifter noise
Nah That would be great if 2 conditions.....my noise would go away after warm up and..... plugged the exhaust forcing it to go somewhere else (like the crack) but nope....so that is ruled out.
  #17 (permalink)
Old 11-04-2009, 06:16 PM
big-o's Avatar
Dealer : Mark Miller Toyota
2002 Toyota Sequoia Limited
Last Online: Yesterday 10:25 PM
Images: 5
big-o is on a distinguished road.
big-o's Photo Albums
Interesting. Does the tick come from one specific side or from the front only? Do you notice it more with the window down or from in the cab? Sounds like it does it when the motor is warm or cold right?
  #18 (permalink)
Old 11-04-2009, 10:31 PM
nivlak's Avatar
2006 Toyota Tundra,
- Other -- 2002 R1
The tick comes from the drivers side. I used a "special" stethoscope and have pretty much located it to the the second cylinder from the front. Of course I notice it more when the window is down. Even with the windows up it is still a distinct sound without the radio on. I have tried to always have the radio on so I wont hear it but it is always there when I turn it off. The sound is there warm or cold as well.
  #19 (permalink)
Old 11-16-2009, 07:26 PM
Last Online: 11-24-2009 07:41 PM
altos is on a distinguished road.
altos's Photo Albums
I have "the noise". It almost... sounds like light dieseling on a cold start-up. It does not occur at cold idle (in park), however, when I put it into gear (D, R, etc.) there it is. It lasts for about 2-3 minutes max, then nothing. Very, very quiet after a minimal warm up. The vehicle runs great (2004 Sequoia) with 138,000 miles. I bought it at 110,000 for c-h-e-a-p and it's been very reliable.
I have tried fuel injector cleaner and higher octane gas, no change. It has a new timing belt. At this point it's almost a "that's the way they are, don't worry, be happy" thing. However, I am very willing to stand corrected if anyone has another perspective.
enjoy,
  #20 (permalink)
Old 11-16-2009, 11:05 PM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
Most likely your dealer need to take valve cover off and check clearance between cams and lifters. That does not take that much time (max 2 hours total). Once they do that, they can tell you if you need to replace shim/shims. I am doing this process on my tundra now. Each shim comes around $6.50 and your sequoia has 32 of them. There is possibility that one or two of them need to be replaced.
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
  #21 (permalink)
Old 11-16-2009, 11:18 PM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 11-17-2009 03:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
enjoy,
The noise I have with my '00 Tundra is exactly as you describe. On mine, it comes from the pistons and has gotten slowly worse over the last 10 years. I'm at 85K now, and found out that it helps to run the engine a bit longer in cold weather before putting it into gear - otherwise it will knock pretty loud (not good!).
Bob
ADDING POWER HAS NEVER BEEN SO FAST!
