Old 02-24-2009, 09:32 PM
Last Online: 09-01-2009 09:19 AM
david3565 is on a distinguished road.
david3565's Photo Albums
Default code po100 maf or vaf circuit malfunction?
installed dvd blew domelight fuse. started car and check engine vsc trak and vsc off lights are on. pulled codes get P0100 maf or vaf circuit malfunction. what do you think? please help 2002 sequoia sr5 4x4
Old 02-25-2009, 01:23 AM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
2004 Toyota Sequoia,
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 10-17-2009 04:39 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
Default Re: code po100 maf or vaf circuit malfunction?
check the two efi fuses
then use the scan tool to read the MAF value Key on Engine off. Then start and compare.
Should be 0 gm/s off, then less than 10 at warm idle
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
Old 02-25-2009, 10:06 AM
thank you soooo much. now i can leave for fla friday for disneyworld. as it turns out, after i blew the fuse to the domelight, my buddy pulled it and said it was bad and said there were spares in the box and laid a spare out for me when i get finished with the install. what he didnt tell me is he pulled EFI 2 fuse out thinking it was a spare. i checked it this morning as you suggested and noticed there wasnt a fuse there at all. replaced it with a real spare and cleared the codes CE light goes out but VSC OFF and VSC TRAK stay on. had to cycle off ignition 1 more time and those lights went out as well. thank you very much, now pray for safe trip and good time.
